Question about Garden
My Honda PowerBoss Pressure Washer is very, very difficult to pull the start rope,and yet when I remove the spark plug the darn thing is very easy to pull and the engine turns over easily.But when you reinstall the spark plug.......UGH!!**##&%##!!! You stand the risk of separating your arm from your shoulder HELP!!
  • 20 Answers
I also have a Honda powered pressure washer that i have experienced the same issues with, I have found that if you pull the wand handle on & let water come out as you are trying to start it it pulls considerably easier.
Posted on Nov 10, 2010
  • victor_roger Nov 10, 2010
    I disconnected the pressure pump and the start pull process is still very difficult
Why won't my honda 5.5 hp pressure washer engine start
check coil for spark remove plug leave coil wire on pull rope see if it has spark if not make sure the coilground is releasing if it is replace coil if is not fix but if coil ok check fuel filter if ok rebuild carburator.
Sep 01, 2014 | Honda Garden
How to fix a flooded engine.
Remove the spark plug and pull the starter rope several times to clean the cylinder, clean the spark plug and fit it back, try to restart the engine.
Aug 13, 2014 | Honda Gx390 Gx 390 13.0 Used Small Engine...
Rope hard to pull
if there is an auto shut off adjust the cable its not pulling all the way open
Mar 08, 2014 | Karcher 2500 PSI Pressure Washer
How to remove pump from a powerboss 020309 power washer
Remove the 4 mounting bolts and it will slide of the shaft if it's not rusted. If it's a little rusty it will take time and some good rust buster applied between the pump and engine onto the engine output shaft. Hope this helps, it's not always the easiest thing to do.
Sep 29, 2013 | Powerboss 020309 3000 psi 2.5...
I put 2 cycle gas in my 4 cycle Honda gcv190 pressure washer
did you pull the spark plug out and clean it ? if you did , did you also put the starter cord and turn the motor over without the plug installed to get rid of the 2-cycle oil out of the cylinder ? if not do so.
Jul 19, 2013 | Honda GCV190-N5AP 187cc GCV190 Series OHC...
Pressure washer hard to pull string
Unless your unit is equipped with an easy start feature...and I think these are not, it is not usual to have to pull the trigger on the water gun to start one of these units. Also...if there is any chance that the washer has tipped over, there is a possibility that oil has gotten into the engine cylinder. Oil will not compress and the rope cannot be pulled..at all. Remove the spark plug and step back away from the exposed hole. Pull the recoil handle and watch for spraying oil from the spark plug hole. Pull a few more times, clean up the plug and the unit may start. If not, you may have to remove the carb bowl and drain more oil. Check your oil fill level. If your gas level is suddenly low you may have gas in the oil crankcase and need to change your oil. When the washer starts it may blow smoke for some time before it clears up.
Oct 20, 2012 | Karcher 2500 PSI Pressure Washer
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
I 'm trying to pull the rope and it will barely--honda pressure w
The rope may be bound up in the recoil. Take the recoil cover off(the piece where the pull rope goes into) and try to pull the rope with the housing off. If it pulls freely try turning the engine by hand, you may want to remove the spark plug to release the compression. If the unit will not turn over,then the pressure pump may have failed. Best of luck.
Apr 23, 2010 | Honda Karcher G4000RH Pressure Washer
My almost new Honda GCV 160 engine will not start.
Hi , I think you need someone to remind you these engins are not made by god and they work by obeying three simple rules ,
1.Spark , Can you see a very good blue spark
2.compression,,can you feel strong compression ,
3.fuel , is the right amount of fuel getting in , is the air mixture good ,
Now try these things
Find the manual and PROPPER set the gap in the spark plug ,
clean and check the air filter ,
remove all fuel and replace with brand new,
check the fuel filter,even in the tank tap?
undo the screw at the carb bowl , can you see petrol leaking ,
If everything checks out then try this to get it started,,
spray "easystart" in the carb , bypassing the air filter ,
if it wants to start but cant for long then its a carb problem
check float hight , float needle,jets and pins ,too much air getting in
find someone thats good on motorbikes , They like me know all the tricks to get things to start ,
Aug 16, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
