Question about Hopkin's Hoppy Trailer Wiring Kit Part Number 47355
2005 ford F350 ,trailer wiring skematic (color & description) with factory brake controller.
    Scholar:
  • 174 Answers
Try this site. http://www.etrailer.com/faq-wiring.aspx. They give color codes and detailed info.
Posted on Dec 16, 2010
1999 FORD F550 WIRE DIAGRAM FOR TRAILER BRAKE CONTROLLER
You have to buy an electrich brake unit ,instruction are in the box.
Apr 18, 2015 | 2008 F250, F350, F450, F550 Wiring...
I have a 2005 ford f550 with factory brake controler & factory trailer wire plug. On the trailer wiring plug I am not getting power to the turn signals or brake lights. The turn signals and brake...
There is a fuse box under the hood that has the fuses that control the wire harness. There are at least 2 boxes, mine were on the drivers side wheel well near the rear of the engine compartment.
Nov 14, 2013 | 1997 Ford F150 Regular Cab
What does tbc fault mean on a 2006 f350
TBC means Trailer Brake Controller fault.Check for moisture/water in the trailer plug connector at the back of your truck. Water/moisture will cause TBC error codes. Look for moisture at all connections to the plug and inside the plug.Trailer brake controller that is built into your dash. If you are hooked up to a trailer it could mean you are losing your connection or ground to the trailer. If you are not connected to a trailer it means there is a problem with your brake controller possibly a short in the wiring caising the fault code. ----- It means either A) you have a bad ground on your trailer. Or B) your cable on your trailer is too short and causing it to pull out of the plug or C) you have a short in the factory trailer harness wiring or the plug is gunked up. --------- get this possibilities checked.It will help.Thanks.Helpmech.
Dec 24, 2010 | 2006 Ford F 350 Super Duty
I have a 2001 F150 and am trying to find out where the factory installed plug in is for the brake controller wiring. I have the brake controller and the instructions say to read the truck owners manual...
Hi. There is a grey plug with 6 wires right behind your OBDII diagnostic port on the lower dash board above your accelerator pedal.
The color of the wires on the plug are blue, green, red, white and brown. The wires are as follows:
Blue....electric trailer brake feed
Green....brake pedal switch
Red...12v postitive...always hot
White....ground
Brown....interior vehicle illumination (not used)
The factory wire harness that you will need to attach your brake controller will plug right into this plug. The factory wires are colored the same as above.
After-market and brake conroller wires are colored as follows:
Red.....brake pedal switch
White....ground
Black....12v positive
Sep 01, 2010 | 2001 Ford F150 Styleside SuperCrew
Which fuse controls trailer lights for 2005 f350
trailer stuff has its own fuse box little on near brake booster usually
May 02, 2010 | 2005 Ford F 350 Super Duty
Tail light wiring connectors and wiring diagram
A test light checking each connector would be faster and easier to do. Maybe somebody may have a illustration for you but by far a simple test light is all you need with a helper turning on the different lights as you check them out and writing all your findings down
Jan 22, 2010 | 1997 Ford F350 Crew Cab
Need fuse list for 2001 ford f350 trailer lights not working
In the fuse box under the hood, fuse in position 20 is a 7.5amp fuse for the trailer left turn circuit, fuse in position 22 is a 7.5 amp fuse for the right turn circuit, if the fuses are good and you have power at them it is going to be wiring, at the back of the truck close to the driver side at the bumper is a gray connector that will take factory wiring to you trailer wiring the yellow wire is left turn/brake light, the green wire is right turn/brake light, and the brown is tail lights, and the orange wire is 12volt feed for if there is a battery on the trailer that needs to be kept charged for break away safty brakes.
Sep 18, 2009 | 2001 Ford F350 Super Duty SuperCab
Hopkin's Hoppy Trailer Wiring Kit Part Number 47355 Logo
1,541 people viewed this question
Top Hopkin's Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Hopkin's Boating Expert? Answer questions, earn points and help others
