Question about Homelite 2.7 Amp. 17 In. Hedge Trimmer
Blade jams can the blade be changed model ut 44110 homelite
  • 183 Answers
After inquiring with Homelite's parts distributor, I have found out the Homelite does NOT offer any service repair parts for this model. A little bit of research tells me why. Home Depot retails this unit for less than $30 here in the USA. To compare, replacement blades for a similar product made by Poulan/Weedeater sell for $26 plus shipping. My guess is that Homelite considers this a disposable unit.
If it was working well for you, go buy another one. For $30, you can't go wrong.
Posted on Nov 11, 2010
I took my homelite trimmer apart to replace the clutch, but now can not get the engine housing to go back on, is there a trick to this ? Model ut33600a
Hopefully this will help if not go to homelite.com ordreing parts then select homelite then string trimmer then find your ut 33600a
Jul 15, 2017 | Homelite Garden
What is the replacement chain and bar for a homelite textron Little Red UT-10748
Ok, what you need to do is go on Google type in that model number UT etc etc and parts right after it. You will see a bunch of sites that have parts drawings, click on one of them, find your part numbers THEN do the same thing again, bqck to google, type in part number then the description, again you will see sites that will either offer the OM part or an aftermarket.
Nov 23, 2015 | Homelite Garden
What is the corrector part number for carburetors fitted on homelite line trimmers model F2020 UT2078
Your missing the last digit of the model number.
UT-20788 and UT-20789 uses the UP00608 carburetor which is a ZAMA C1U-H39.
Mar 28, 2015 | Homelite Garden
Homelite trimmer ut 15151 How do I replace pull
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers
Nov 10, 2010 | Homelite Garden
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
My homelite chainsaw model# ut10520 has aoil leak from the flexible line at the base of the oil tank.
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 07, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Where can i fined spares for homelite f-3035 bush cutter ,thank you ,tom
Spare what? Blades, Tires, Parts. Be more specific.
Do you have a ut-xxxxx model number for this unit. The other model number you show does not come up in any data base.
Sep 24, 2009 | Homelite Garden
Got a homelite ut 15039a (weedwacker with blade st 185)
You have the rong fuel tank for that model.Thats the return pipe its comming from so you can drill a hole if youwant but make sure its sealed properly.
Jul 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite 2.7 Amp. 17 In. Hedge Trimmer Logo
509 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
