Question about Cisco Photosmart C4780 Wireless AllInOne Printer With Linksys By Cisco WirelessN Broadband Router
My photosmart c4780 keeps going idle when i print stuff. it was finee a few days after i bought it but now, it keeps going idle and will just stay there.
HP Photosmart C4780 and Acer Aspire fight over web-based printing!
Try hard-wiring your laptop to the router with an ethernet cable as a test and then try printing, if you do not loose connection to the internet then the problem is probably that the printing is hogging your wireless bandwidth.
If the same thing happens with loosing connection to the internet try connecting to the internet real quick through another computer that is hardwired, you want to find out if the problem is a wireless one or that affects wired computers also. You might need a driver upgrade, you also might need to upgrade the firmware of the router
Jan 22, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
Incompatabe ink cartridge?
Yes it could be the problem. Try and get a different print cartridge and if it doesn't work you may just have to get a new printer.
Apr 30, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
My hp photosmart c4780 won't align because is keeps saying that the alignment plot in the scanner is skewed
If you have had paper jam and not replaced the rear paper grey plastic retainer correctly or somehow it has become loosened the paper will twist on entry and the printing will be askew. Sometimes not loading paper. It will then also not align when replacing cartridge. Had this problem, took out the retainer that has two plastic points that should locate in the retaining holes and pushed it back. Paper jam, printouts and alignment was then fine. Took me months to figure out as it was printing, just not very straight
Jan 24, 2012 | Office Equipment & Supplies
My HP Photosmart C4780 makes the loud clicking sound. This just started and it still prints ok. Less than a year old.
There could be something stuck inside. Look inside and inspect to make sure there's no paper or anything else clogging in
May 20, 2011 | Cisco Photosmart C4780 Wireless AllInOne...
HPC 4780..Printing fine from computer. but will not scan or copy when i press the button on printer. Get a message that scanning/copying failed.
Uninstall the driver for your HP C4780 and reinstall it using this page.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3794615&lc=en&cc=ph&dlc=en&lang=en&cc=ph
If you are not familiar in doing so, you can call HP on this number: 800-474-6836 (United States)
Mar 25, 2011 | Cisco Photosmart C4780 Wireless AllInOne...
Cannot connect my laptop to wireless
Your wireless printer might frequently lose its communication with the computer and hence might not print all the documents when you want. Such an issue arises when there is interference in the wireless signals between the printer and the computer. This could be caused by any other wireless device kept in the vicinity of your printer like a cordless phone. Keep all other wireless devices way from the printer set-up to tackle this issue. Also bear in mind that if your system is turned on for hibernation mode then it would disconnect your printer the moment it goes into hibernation. get more help http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/HP-Photosmart-C4780-Wireless-Printing/m-p/320321#M19172
Sep 06, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
Cisco Photosmart C4780 Wireless AllInOne Printer With Linksys By Cisco WirelessN Broadband Router Logo
167 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
