Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Compressor Relay I just replaced my relay, and the fridge works like a charm. (Thanks to reading some solutions on this site) I used the old overload protector after the appliance guy tested it and told me it was fine. The question I have is that when I was puttig the cover back on while the compressor was running, I noticed that the copper that comes out of the compressor was extremely hot to the touch. It hadn't really even been running long. Is that normal? I guess I'm concerned because of the other articles I read about Kenmore refrigerators smoking. Thanks for your help
  • 85 Answers
Remove toe cover from front of refrgerator and clean the condeser coil, if the condensor coil is block that is the cause for the start relay to have failed
Posted on Dec 14, 2008
I have a Haier mini fridge that is not working. I have taken the P6R8MC relay off but don't hear any rattle. Does that mean the compressor is probably bad?
That is what is sounds like but let's check. An overload relay will fail due to wear, a short or a bad compressor will knock it out. There is a rare occasion you may purchased a bad overload relay, but that is rare. The rattling of the overload relay is a good indicator it is bad, however it does not have to rattle to be bad - inspect for burn marks as well.
The clicking sound is the overload relay trying to start the compressor. There will be a pause and then click trying to start the compressor again.
Remove the overload relay component and expose the three pins on the compressor. Using a multi- meter, measure the Ohms across the three pins. You will get one high Ohm reading and two lower Ohm readings. If the two lower readings add up to the higher reading the compressor is good. Make sure the green ground wire is securely grounded. It could nock out the overload. Check for loose connections. Replacing a compressor is a major repair. The cost will exceed the purchase price. Rule of thumb; "If the cost of the repair is 1/3 or more of the purchase price of the unit, Buy new".
As a retired Sears service technician, we considered these units
as throw-a-ways due to the high cost of repair. If you had a service contract we would replace the unit rather than repair it
Oct 18, 2014 | Haier Refrigerators
My samsung RF4287 (french fridge doors and freezer on the bottom) will not freeze.
check if there is build up of snow in the freezer behind the cover.
possible defrost problem
May 14, 2014 | Samsung Refrigerators
I replaced the relay overload on my kitchenaid refrigerator but the compressor still wont come on woke up in the morning fridge was warm i checked it compressor was not on it was very hot i took off the...
There are some checks that you should perform.
First remove the PTC relay and thermal overload.
Next do a resistance test of the 3 compressor terminals that are labeled as follows
C = Common
R = Run
S = Start
Read Each of the 3 terminals to the case of the compressor. NO grounds are allowed. Then read C to R and C to S. You must read resistance.
Last test is an amperage test with the PTC / Overload connected. You look on the compressor LABEL for the letters LRA and note that number that will be somewhere between 13.8 and 21.3 amps. You then measure the amperage on the power cord... or near the compressor. If the number of amps read is equal to or greater than the LRA (Locked Rotor Amperage) then the compressor rotor is infact locked and the compressor will have to be replaced. If it is trying to start and your sure the rotor is turning but it is not running at full speed you may have a bad run capacitor. Since you installed the 3 n 1 device I doubt you have a capacitor problem.
Thanks for chosing FixYa,
Kelly
Jun 22, 2011 | Refrigerators
Hello there, I have a GE model GSH 25 JF side by side fridge. I believe it's a 2005 model. The Freezer and Fridge are running, but neiher is cool at all. There is a clicking noise happening about every...
Sounds like you have a starter problem. There is a part on the compressor used to start up. It should be if I remember correctly a capacitor near or on the motor. When the light dims it is trying to start up but failing.
Sep 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Help!i have a maytag refrigerator model #mtb2172hr that stopped getting cold on and off and i hear a buzzing noise on and off around compressor area.the fridge is 5 yrs.old.i hear the motor and fan still...
Sounds like a bad overload relay capacitor on your compressor, or a bad compressor. If it is under 5 years you usually have a 5 year sealed system warrantee that pays for parts and labor on the compressor. It does not pay for a relay overload capacitor. The problem is some warrantee companies will void your warrantee if you or an unauthorized servicer works on your unit. I would recommend you have maytag send out a technician to diagnose this, mainly because I have seen a lot of bad Maytag compressors lately. If it is over 5 years old you can replace the overload relay capacitor and test to see if it works. Before you do this you should remove the old overload relay capacitor from the compressor and do a continuity test between all three terminals and between the terminals and the compressor case. You should have continuilty between the terminals but not between the terminal and the case. If you dont have continuity between the terminals or if you do have continuity between a terminal and the case, then you have a bad compressor. Do not install the new overload relay capacitor as you cannot return these to the parts house once they have been installed. Even after all the tests and even if your compressor starts up you can still have a compressor failure within a couple of days. A technician can hook up your compressor to a tester and determine if it is good or bad. If a compressor is bad it usually costs 900 to 1100.00 to replace through any of the service companies in my area. Not worth repairing. Hope this helps, Appliance Specialists
Dec 15, 2009 | Kitchen Ranges
Neff fridge, compressor makes nasty noise,
Hey there you need to check the motor/compressor PTC start relay which is located on the side of the compressor under the plastic terminal cover, it's mounted on start and run winding pins the third pin is the incoming phase which has a overload connected to it .if this relay stays shorted or doesn't conduct to power the start winding the motor/compressor wont start. also if there's a motor start capacitor test that. tell me how you get on as i have more solutions if that doesn't help.
Please rate my advice too
cheers
steve
Mar 25, 2009 | Refrigerators
Help w/ Refrigerator Compressor Overheating?
I had a similar problem yesterday (Maytag side by side unit 5 years old, however this apply to most brands). All operation seems normal other then that the refrigerator was not cooling, the air that was blowing inside the refrigerator was room temperature and not cold air. The compressor was also very hot to touch (could not touch it for more then 1-2 seconds) and didn't buzz or hum as in standard operation. I also heard few clicks from the compressor every time I plugged / unplugged the AC to the fridge. Replaced the overload/ relay device with a new one I got at a local appliance parts distributor ($30) and MAGIC. The unit went back to work as soon as I plugged the AC power. The relay/overload unit is on the side of the compressor and that?s where the electric wires are attached to. The unit turns the compressor on and off. The unit is attached to the compressor side with an "electric outlet" like three holes and three prongs. It might be held tight so you can pry gently (between the unit and the compressor body) with a screwdriver. Once pulled out, release the wires connectors that are attached to the relay/ overload unit. You might need to use pliers as they are tight fit. If unit smells like burnt or if you shake and hear rattle then it?s bad. Find a local appliance parts distributors and call to see if they have part for your model/ type. Remember to unplug AC before starting to work on the fridge and good luck.
Jun 29, 2008 | Refrigerators
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Compressor & Relay
Erik,
If the compressor does not run, it is an electrical issue. The relay might be bad. Is there power going to the relay/ compressor? Use a volt sensor to determine this. Before I would replace the compressor I'd replace the relay. "Johnstone Supply" has refrigerator parts. Is it clean? It almost sounds like the "overload" has tripped and is not resetting.
Apr 03, 2017 | GE Refrigerators
No cold in fridge or freezer: buzzing compressor
There is no start motor. If the brand of the compressor is a tecumpseh then it is most likely the problem and has a 5 yr warranty from the date of purchase. If it is an Embraco compressor I would try and overload and relay. They are all in one part sometimes called a start device.
Sep 24, 2007 | Amana ARB2217C Bottom Freezer Refrigerator
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
179 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
