Question about Mitsubishi VS-60707 60" Rear Projection Television
Set turns off on its own
Turns on then shuts down sometimes 1 hour sometimes 20 minutes
  • jagjeffers Jun 17, 2008
    it blinks 1 and then 2, I am asumming that would mean 12
  • Mitsubishi Master
  • 8,617 Answers
When it shuts down press menu and input buttons both in together on the front panel and hold in for 8 seconds and see if the LED blinks a two digit code . If so let me know the number of blinks
Posted on Jun 17, 2008
  • Sonny Berry
    Sonny Berry Jun 17, 2008
    yes, however a 12 code means that the set isnt shutting down for protective reasons. So it will need to be diagnosed. But if your good at soldering you may want to try re-soldering the Flyback and the components near the flyback as mitsubishi has had some issues with solder joints at the flyback and horizontal drive transformer
Denon 1909 flashing red ring after 20 minutes
Well on most models red ring singals :
1 ) speaker wires touching something they should not
2 ) internal overheating, shutting down to protect
3 ) something is wrong, bring in for service.
I'm guessing it's out of warranty?
Dec 25, 2013 | Denon Audio Players & Recorders
Projector shut down
happened to me something similar to what reported, only the small fan sometimes went off within minutes and sometimes seemed to work for hours
The room temperature was around 20 degrees, so the problem was software or hardware, but on the internet I did not find other people with this problem or fix
I did not update the firmware for the loss of the warranty, which I am thinking of claim
Feb 12, 2013 | Optoma ML300 Multimedia Projector
I have a 2001, Panasonic 27
Suspect either bad solder connections somewhere or a issue in the power supply of the set----set will shut down for a number of reasons--it monitors voltages inside and if some go high or low it will shut down.
May 16, 2012 | Televison & Video
Hello, my Marantz BP8002 keeps shutting down intermitantly with different type disks. Does not matter if it's Blu-ray, DVD, or DVD-R. It will sometimes play for 2 minutes and shut down completely....
If it shuts off at different time intervals, there might be a loose connection that needs to be solder. Ask for a repairman to check it.
Oct 25, 2010 | Televison & Video
How do i program the timer?
You did not specify UPM outdoor timer model.
1)ET525C has 7 buttons, and is shaped like a computer mouse, and has a photocell
2)DT420 & ET420 are dusk-to-dawn timers with clear plastic cover
3)DT523 is dusk-to-dawn and shaped like apple phone
4) PT555 is box-type with a door and timer has 6 screw terminals
I'm going to shoot-wild and offer programming for the one shaped like a mouse, the ET525c.
Here is manual
Download manual if you have high-speed, so you can see print larger.
Manual has 10 pages so I can't repeat everything. You will have to read along with your copy of manual.
1) Timer has MODE choices: I will help you program specific on-off times.
2) Setting the clock: Press SET > press Up-Down to choose day of the week ... if today's newspaper says Friday, set timer to Friday
3) Press Set again to confirm day of week
4) Press arrows to set hour. If your watch says 10:30 am, click arrow until 10 am shows
5) Press Set to confirm hour
6) Press arrow to set minutes, until minutes match your watch.
7) Press Set again to confirm everything.
Clock is displayed now
Programming timer:
Timer gives you 20 programs
PROG1 PROG2 etc to 20
Each program needs a DAY it will operate
Each program has ON time, and OFF time
PROG1 ON
PROG1 OFF
Select PROG1 using UP key
Manual page 6 has diagram showing how display looks
Press UP until PROG1 ON shows
Notice: PROG shows in upper right corner, and 1 ON displays to the right of time
This means PROG1 ON
Note: sometimes the instructions say press UP, and sometimes they say press UP or Down ... when in doubt, write out the instructions, and it helps you understand.
Now press Set to begin
Press UP and different days will show. MO for Monday, Weekdays, weekends.
Press Set to confirm days you want PROG1 to turn ON
Press UP or DOWN to set hour you want PROG1 to turn ON
Press UP or DOWN to set minutes you want PROG1 to turn ON
Half way done with PROG1, you need to set PROG1 OFF times
Press UP until PROG1 OFF shows
Look at display, and look at figure page 6 manual
To right of time is number 1 with tiny word OFF, in upper right corner of display is PROG
Press Set to start
Press arrows until day shows (default will flash same days you picked for ON times) Tip: keep the same days!!! or timer will reset ON times for some reason.
Press Set to confirm days timer will turn PROG1 OFF
Press UP and DOWN to set hour for PROG1 OFF
Press UP and DOWN to set minutes for PROG1 OFF
To advance to PROG2, PROG3, PROG4-20, press UP key
To end programing mode, press DOWN
If no keys are touched for 1 minute, timer returns to clock mode
Instructions carry on with more options, if problems persist, take aspirin and post again in the morning.
Oct 04, 2010 | UPM Heavy Duty Outdoor Programmable Timer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Mitsubishi Projection TV WD-62525
this set has 3 temperture sensors.If the set gets too hot it will shut down.
first clean the cooling fan as it may be full of dust.
if this is not the cure the one of the sensors is likely bad.
Thanks Guy9
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
