Question about kawasaki Garden
Dear Sir/Madam, I have a Kawasaki Grass Trimmer model: TD-33, which I have problem to start, even though I try to change the spark plug many time. One thing I notice on the spark plug is that, when ever I removed from the hole, I notice the plug was wet at the contact lead. I suspected the Oil/Fuel ration is too tick, but on top of the filling cap, there is a ration stating 25 Gas/1 Oil. There is a spark generated when I test the plug out side. But the engine still can not started up. after so many time try. Pls advice and assist me to how to troubleshoot. Thank you very much. Rgds, Wong S.C.
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
goofduck
  • 490 Answers
SOURCE: Craftsman rider 19.5 hp won't start
check to make sure you are getting fire
Posted on Apr 27, 2009
  • 226 Answers
SOURCE: Craftsman Chainsaw will not start
It's your ignition, which you can take that stuff apart on the left hand side of the saw under the recoil. I have 2 of these, & you can get the parts. Maybe its just the magneto gap adjustment, which is like a business card or newspaper width gap. I would check that first. Hope this helps you, Rick
Posted on Apr 29, 2009
  • 10865 Answers
SOURCE: cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
Posted on May 10, 2009
da420bmx
  • 4 Answers
SOURCE: 19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
Posted on May 19, 2009
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Grass Trimmer
how to play blackberry media files on samsung hm1100 bluetooth
May 07, 2013 | Garden
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
Apr 07, 2011 | Craftsman Convertible 25cc. Gas Line...
Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Apr 28, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
My grass scorpion willn't start,I have changed fuel with a new mixture & spark plug,still no start & plug wet with fuel & exhaust.Any help to the problem appreciated-dealer give me DJ8J spark...
To make sure that you have the right plug,you need to specify the make and model number of your trimmer.The first thing you need to do is check and make sure you have spark to the plug.
Set the trimmer down.Take out the spark plug.Put the plug into the plug boot and set it on top of the motor.Make sure the switch is on,and pull the recoil a couple of times.Look at the end of the plug to see if you have spark,and make sure it is blue.
If you have spark,you might have a problem with your carburetor settings.
Sep 04, 2009 | Ryobi Garden
Grass trimmer will not start
check for spark, check that spark plug is not fouled or coated. Check to make sure gas is making it's way to carburator. Make sure fuel hose is not kinked.
If trimmer is not getting spark, the coil may need to be replaced or flywheel and coil contacts may need to be sanded, ligthly filed or use hemricloth
Jul 09, 2009 | Garden
Trimmer model: Sears 358.796121: no start
Could be a faulty kill switch not allowing it to start, sounds like you covered all the things I would check.
Jul 09, 2009 | Craftsman 25cc Gas Line Trimmer
Bike wont start
sounds like carb issues, check fuel contamination and **** in carb first.
Mar 22, 2009 | 1998 kawasaki KDX 200
Garden Logo
210 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
