Question about Panasonic SR-LA18N 5-Cup Rice Cooker
H02 on screen can't press anything - Panasonic SR-LA18N 5-Cup Rice Cooker
ERROR CODE H02 ON MY HOOVER SENSOR DRY WASHER DRYER WD9616C
Hi I have the error code ho2 on my Hoover wash machine does any one no what it means
Oct 21, 2012 | Washing Machines
Lent removal hoover dynamic 9+6
I have H02 on my washer dryer, all i can do is turn it on and off, i wont do anything else, what can i do to get it to work?
May 05, 2012 | Washing Machines
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
How to replace the oxygen sensor
Removal & Installation Upstream HO2 S1 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the HO2 S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO2 S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO2 S1 sensor. Tighten the HO2 S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO2 S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO2 S2 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the H02 S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the H02 S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H02 S2.
To Install:
  1. Coat the threads of the H02 S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the H02 S2. Tighten the sensor to 30 ft lb (41 Nm).
  3. Connect the H02 S2 sensor electrical connector.
  4. Lower the vehicle.
Oct 07, 2010 | 2001 Buick Regal
Dvd will not play. H02 appears. Have reset to no
H02 is a fault code, though I don't know what. It code be either an electrical fault or mechanical problem. A mechanical fault might be easy to spot so take off the top cover and see if anything is broken, otherwise I suggest a service manual will come in handy.
May 21, 2010 | Denon DVD-800 DVD Player
H02
The HO2 message means the disc is not spinning,it's not about the lens
or the laser.It is easy to take the lid off.Once you do that,plug it in,open the tray with the remote,put in a DVD,close the tray and then give the white plastic wheel on the top a gentle little nudge to get the disc spinning.
Jan 30, 2010 | Panasonic DVD-LS50 Portable DVD Player
Error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
HO2 error code at screen
In line with the other Panansonic DVD players, the error seems to relate to the internal drive machanism getting stuck.
To fix you just need to carefully take the back off (disconnect power source first!), locate the drive cogs for the lens machanism and give the a couple of turns. Also a blast from a air can will help get rid of any dust build up. Pop the back cover back on and you should be working.
Looking at the other Panasonic threads on the site, this may happen on a regular basis especially as the unit gets older (and the crud builds up).
Jul 10, 2008 | Panasonic DVD-LS5 Portable DVD Player with...
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
No Longer Plays discs
You should try this site. It worked for me. Also after fixing you should try and remove anything that may be on top of the DVD as this seems to cause the issue. We have had our S35 for at least 4 years and today was the first time I got the error.
http://wiki.xdroop.com/gallery2/v/Random/0706_001/IMG00104.jpg.html
Sep 01, 2007 | Panasonic DVD-S35 DVD Player
Panasonic SR-LA18N 5-Cup Rice Cooker Logo
108 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
