Question about Sharp AL 1631 Copier
Woodpecker noise II
Hi and thank you very much for your response. I would like to answer your questions about possible codes or the status of side door as follows.
Side cover. The side cover closes without any indication of misadjustment. We tested again applying pressure to the closed cover but the sound continues.
Codes. There are no codes shown on the screen. This machine is working great as always except for two things:
1. Multi-bypass tray. The feeding mechanism of the multi-bypass tray is not working when requested using the operation panel. This is the only section of the machine that is not working.
2. Woodpecker noise. This noise has a frequency that is similar to the pass/gap between gear teeth. It comes from an area that includes the side cover and the rear part of the machine close to the side cover. This frequency makes me think that probably a gear might be hitting a mispositioned plastic part of the feeding mechanism in the multi-bypass tray.
Depending on your recommendations, I am planning to open up the section located between the paper tray and the multi-bypass tray beneath the copier.
Please let me know your comments about this.
Regards,
Charliegreen
  • CharlieGreen Jun 19, 2008
    Thanks again!
    Can you believe this: my assistant hit the side of the machine with a girly blow and the noise disappeared!!!
  • Sharp Master
  • 2,794 Answers
A lot of times when this happens those grears need to be replaced. If you find a Sharp dealer in your area, they shold be able to fix it for you.
Posted on Jun 19, 2008
  • Tim Babcock
    Tim Babcock Jun 19, 2008
    Thats a scary thought. I suppose that will work for now. It could come back.
I keep getting Expected status code(200-209) got 503
  • ios - expected status code in (200-299) got 503 - Stack ... stackoverflow.com/questions/23807162 I got the following error expected status code in (200-299) got 503. I didn't get this all the time. ... RestKit 0.2 Error 'Expected status code in (400-499), got 200'
  • expected status code in (200-299) got 403? ' Yahoo Answers answers.yahoo.com > Computers & Internet > Software > Next
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    • PUBLISHED 2012-12-04
    ... expected status code in (200-299) got 403 what should i do? Add your answer. Source. ... Expected status code (200-299) got 410? Expected error ...
  • ios - Expected status code in (200-299), got 500 - Stack ... stackoverflow.com/questions/21828128
    • LAST UPDATED: 2014-02-17
    • 1 POST
    • FIRST POST: 2014-02-17
    ... NSLocalizedDescription=Expected status code in (200-299), got 500, ... expected status code in (200-299) got 503. 0 SOAP response/Request then how to convert it ...
  • WordPress for iOS Forums » Error: Expected Status code in ... https://ios.forums.wordpress.org/topic/error-expected-status-code... WordPress for iOS Forums » How-to and Troubleshooting. Error: Expected Status code in (200-299), got 503. juangaso Member Aug 22, 2013, 4:29 PM. Hello.
  • expected status code in 200-299 got 500 « My Site My Way ... mysitemyway.com/support/topic/expected-status-code-in-200-299-got-500 expected status code in 200-299 got 500 (32 posts) (3 voices) boldprint Member. I can no longer add posts to my site from my iPhone w/ Wordpress for iOS app since ...
  • Feb 08, 2016 | Apple iPad (16 GB) WiFi Tablet PC
    Woodpecker problem
    Hmmm.
    Since this question is in the Washing Machine category, I would tie a string to the lid of the washing machine, and put woodpecker food inside it. When the woodpecker flies in to get the food, pull the string and the lid ill close, catching the woodpecker.
    Jun 13, 2015 | Washing Machines
    I have a 2001 Ford F150 XLT with a 4.2L manual trans I am have a problum for the drive cycle to compleate I have a NGS scanner and 3 mo ago i clean the o2 sensor the check engine light has not came on for...
    P0100 OBD-II Trouble Code
    Technical Description
    Mass Air Flow (MAF) Circuit Malfunction
    Basically this means that there's a problem with the Mass Air Flow (MAF) sensor or circuit.
    You will likely not notice any serious driving problems, but there may be symptoms like a general decrease in power or sluggishness.
    Causes
    A code P0100 may mean one or more of the following:
    * The MAF may be disconnected, or a wiring connection may be bad.
    * The MAF sensor may be faulty.
    Possible Solutions
    Use an OBD II Reader (or go tou your local parts store and they will for free) and reset the code and see if it comes back.
    Then start with the cheapest, easiest repair procedures:
    * Check the Mass Air Flow Sensor wiring/harness is connected properly and that there are no broken / frayed wires.
    * Unplug and reconnect the MAF wiring harness a few times to clear the contacts.
    * Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information).
    * Replace the MAF sensor.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jul 05, 2010 | 1996 Ford Explorer
    I need a parts diagram for a 3M Polygun II hot melt gun.
    Thanks for your question!
    I'm sorry that you haven't received an answer yet.
    The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
    1. the question is unclear, incomplete, or poorly worded...
    2. the question is mis-categorized - so the correct experts aren't viewing it...
    3. the question requires an answer for something that cannot be explained online adequately...
    4. specific training, tools, or equipment are required to avoid injury or death...
    5. the Experts that are online simply don't have the resources to answer your question fully...
    Please feel free to re-work your question if you feel one of these may be the reason.
    Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
    Normal rates for FixYa are...
    $ 9.99 answer for one question.
    $12.99 Live Real-Time online chat or premium e-mail support.
    $29.99 Live Real Time phone support
    Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question.
    May 20, 2010 | 3M Polygun Ii Glue Gun Adhesive Applicator
    My built in side by side is making a noise about every 30 minutes or so that sounds like a woodpecker pecking on it...about 10 times. It is driving me crazy! Have any idea what this might be?
    I have the exact problem with my built0in side-by-side Monogram. 1 yr 3 months old, and it sounds m=like a woodpecker for 3 seconds approximately 1ce/hr. Does not appear related to ice maker. You can create the sound by changing the temp setting on the drawer at the bottom. As you command a lower temp, the sound happens a couple seconds. Actually sounds like a solenoid opening and closing at 60Hz frequency, as though a control board were feeding AC to a DC coil. Any ideas? Fortunately, this fridge has a 2 year warranty, but this should not happen to a $6K dual condenser fridge in just over a year!!
    Jan 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
    Pentium II, just know the hardware in Pentium II
    Go to Ask .com for the answer to these and many oyher questions.
    Jul 07, 2009 | Computers & Internet
    Intermittent rattling noise in refrigerator
    Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
    Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
    Hope this helps.
    Jun 27, 2009 | GE Monogram Refrigerator Built-In...
    We need parts replaced on our Tec - Patio II grill
    Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
    Your problem solved - guaranteed! Or your money back!!
    If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
    Mar 05, 2009 | Tec Patio II Grill
    Woodpecker noise II
    A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
    Are there error codes on the screen?
    Make sure the right door where the bypass tray is closed all the way.
    Jun 16, 2008 | Sharp AL 1631 Copier
    Sharp AL 1631 Copier Logo
    79 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    jasbo
    jasbo
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
