Question about Canon FAX-B160 Plain Paper Bubblejet
Loaded a new BC02 cartridge in my B160 fax and the print is faint and hard to read. The cartridge was in a sealed package. Could the ink cartridge have dried out or do you think my fax is broken.
  • 286 Answers
SOURCE: printing
Likely your purge unit needs cleaning...
Make sure by printing out a test page from printer (not from computer).
If test page is good, you have a software issue. If test page is bad, you need to clean your head and/or purge unit.
Posted on Dec 30, 2007
  • 36 Answers
SOURCE: Canon Fax B160 sending fax troubles
The fax transmission speed was set to 14400, we have solved the problem by putting down transmission speed to 4800 and now emission works without troubles.
Posted on Mar 07, 2008
printerman40
  • 170 Answers
SOURCE: Brother Intellifax 2800 Faint Print
did you remember to remove the pull tab to allow the new toner to be utilized? it's either that or you just have a defective toner cartridge which if you replace will take care of the issue. If you have used canned air to blow out your machine it is possible that the toner dust has been blown into the laser housing and fogging up the mirrors that it uses but that's kinda a last resort check...
Posted on May 07, 2008
  • 105 Answers
SOURCE: Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
Posted on May 12, 2008
SOURCE: Canon i960 will not print in black ink
I use a no. 4 pan head screw to drill a SMALL hole in the top of the ink cartridge, about 1/4" in back from the front edge, so you can reseal it with the screw when done.
Take a small syringe with a short needle and pull the plunger back.
Insert the needle into hole and hold cartridge in place, IN THE PRINT HEAD, while pushing the plunger down to "pressure feed" the ink into the print head.
Reseal the ink tank with the screw when done.
I think the problem stems from the new or refilled ink tank NOT making a good seal with the print head and then there is a vacuum leak at the joint.
I have done this many times with my various Canon printers with removable ink tanks and it almost invaribly works for me.
I also refil the ink tanks IN THE PRINTER rather than taking them out to help prevent the vacuum break between the print heand and the ink tank.
It also helps to use a photo printing program to "print" out a black, red, blue or yellow page (use whichever color you are having trouble with) to help start the ink flowing again as well.
It does not have to be a full 8 x 10 size, just something about 4 x 6 to help reestablish the ink flow.
Posted on Jul 17, 2008
I have an HP 2140 fax purchased one year ago. I have never replaced the catridge and have used the fax about once a month. Today I am trying to copy and it won't print. I cleaned the nozzle and still...
New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
Apr 12, 2011 | HEWLETT-PACKARD HP 2140 Fax
I have an HP L7680. I have all HP ink cartridges. The printheads read monitor and good. I have printed the diagnostics page and aligned and cleaned the printheads and calibrated. No matter what I do...
Cleaning the print heads can sometimes help and other times aggravate the problem, because cleaning takes a lot of ink out of the cartridges. If the cartridges are emptied using the cleaning procedure, then the cartridges will have to be replaced with new ones.
The ink jet information provided by hp's software can sometimes be just an estimate of how much ink is in the cartridge and not an actual reading by the electronics. So... Try new ink jet cartridges fresh from a package to see if that solves the problem, and make sure that the contacts are blown free of dust or dirt.
Good luck on this repair.
Dec 14, 2010 | Office Equipment & Supplies
The memory is full and my fax keeps reading no ink. I replaced the cartridge twice and it still reads no ink. It is a UX B-20
Don't worry about the memory being full, the problem is the ink, and once the machine is able to print the FAX will empty memory by printing the faxes out. This might sound bad but I have seen this happen, when you unpacked the new ink cartridge, did you pull off the little plastic protector? And is the paper loaded?
Dec 03, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
No print on rec'd or sent faxes
Surely you don't have blank copies rec'd and sent as these are two different parts of the machine entirely. I'll assume you mean rec'd and copied. Sounds like you've left a packaging seal on the cartridge to me - or it's a faulty cartridge. Remove the cartridge and check that all packaging has been removed - especially plastic strip that prevents toner from dropping into the cartridge.
Jul 01, 2009 | Canon FaxPhone L75 Plain Paper Laser
OfficeJet G85 Makes Unreadable Copies
Usually, it's the print cartridge. I recently installed a new black cartridge on a 6110 printer and it, too, was very faint in printing. It turned out to be "dried up", even though it was a new cartridge in a sealed bag (but purchased in 2005).
Feb 07, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Color not printing
If you are making copies or sending/receiving faxes Press Black Start or Color Start. Make sure your ink cartridges are fresh. Cartridges remain fresh for up to two years if kept in their original packaging, after that the ink may become clogged. Cartridge expiration dates are printed on the package.
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
May 07, 2008 | Brother IntelliFAX 2800 Laser Fax
Ink Cartridge not recognized
Use only Genuine HP ink cartridges.
Apr 11, 2008 | HP 1040 Plain Paper Inkjet Fax
Waste ink near full error message
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Nov 01, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Deteriorating Print Quality
This is Maltesecross. Turns out that the faintness of my printed pages was in fact due to a low ink cartridge, even though some pages printed out fine and others half-good. Eventually, all pages turned faint, and upon re-installing the driver, I got a low-ink warning (the first one ever). Putting in a new ink cartridge solved the problem for me.
Oct 21, 2007 | HP Photosmart C3180 All-In-One InkJet...
Canon FAX-B160 Plain Paper Bubblejet Logo
old marine
old marine
