Question about Motorola CLS 1110 (1 Channel) 2-Way Radio
My Motorola CLS1110 Two way radio has issues charging. I have a 6 station charging station and when I put the walkie on the dock to charge the light just contiues to blink red. I have to continually readjust the walkie for the light to turn solid red if it will at all. Please help.
  • Motorola Master
  • 1,654 Answers
You may have a bad battery, or even dirty battery contacts. A few troubleshooting ideas include:
1) Swap the battery to another known good CLS1110 radio and see if the other radio has the same problem when placed on the charger. If so, you have a bad battery. This type of battery typically lasts approx. 18-24 months before needing replaced.
2) If swapping the battery proves to be successful, check the battery contacts on the affected radio for debris, scum or dirt. Clean the contacts on the charger and the radio with a pencil eraser if needed. (The fact you have to readjust the walkie in the charger indicates you might have problems with the contacts.)
3) Try the battery from the known good radio in the affected radio, if the battery charges correctly, you know the radio is fine. If the charger blinks with the known good battery, then you know you have a radio problem.
Best regards.
Posted on Nov 10, 2010
    New Friend:
Hi!
i have a same issues except my charging dock keeps blinking ref even when not charging.
Posted on Aug 26, 2015
I have a charging station for the Motorola T8500 walkie talkies which holds two of the T8500. When plugged in only the back slot can be used charge. The front slot does not work.
This is common. For some reason, the GMRS chargers of all brands break often. Unplug the unit. Try lightly sanding the contacts on the front cup/slot. Make certain you do not push them in too far. If you do, carefully pull them out. They should be bright. Then clean the contacts on the radio. If it still does not work, use a voltmeter and test the power is getting through to the battery from the charging cup. The voltage is DC and should read anywhere from 6-12 volts, maybe more.
Nov 11, 2016 | Motorola Radio Communications
Wont charge
Contact Motorola Solutions Support
portal motorolasolutions com
Mark
Motorola Mobility Support
Jun 19, 2014 | Motorola Cls1110 Cls 1110 Cls1410 Cls 1410...
Where and how can i get a charging station for a Motorola Talkabout T5530 Walkie Talkie?
Hi Ken,
Take your radio in to your nearest Radioshack or similar store, and they'll help you to get the Charging dock for your radio.
I hope this helps.
Cheers,
Peter
Aug 07, 2012 | Motorola TalkAbout T5530 2-Way Radio
How do i replace the antenna to a cls1110?
Replacing the antenna is rather easy and will take only a few minutes. Please see a short YouTube video on how to do it. Parts are available on ShopWiscomm.com Amazon or Ebay
https://www.youtube.com/watch?v=JbQn-6-xgPk Motorola CLS1110 CLS1410 Replacement Antenna Installation Instructions
Dec 02, 2011 | Motorola CLS 1110 (1 Channel) 2-Way Radio
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
Have a Motorola 2 way walkie talkies but misplaced the manual on how to operate the unit. Bought these at Canadain Tire about 5 yrs. ago. Not sure if 1XTN4004B or CH600 is the model number. Please advise...
Haven't been able to locate a user guide for the multi-unit charger. However, it is pretty much plug-in-n-play. It can charge a battery inside a radio, or also accommodate a battery alone in each of 6 cups. As for replacement parts, they are not available, and you cannot purchase the multi-unit tray separate from the power supply. This is a slow rate charger and would take 10 hours to charge your batteries (or overnight). Radios/batteries should only be placed on the charger when nearly depleted. (Consider your charge a place your radios go to bed overnight.)
If you are having difficulty with charging, clean your battery contacts on the exterior of the radio and inside the charger cups with a pencil eraser.
This tray can act as a radio cloning station. See page 23 about cloning in the XTN radio user guide: http://www.123radios.com/manuals/xtnmanual.pdf
Best regards.
Jan 09, 2011 | Motorola XTN-Series Multi-unit Charging...
Walkie talkie batteries don't last
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
I unplugged the docking station and now does not work
I actually had the same issue with mine.. it was 6 years old and just stopped finding the docking station. Also wouldnt take a charge. So I just eliminated the docking station. The stations power cord will charge the unit. Hope this helps.
Sep 12, 2009 | Roomba Robotic Floor Bagless Vacuum
Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
1,136 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
