Question about Audiovox AVP7200 VHS VCR
Audiovox avp-6750m dew light keeps blinking. Tape will not play
Theres something on the vcr yhat says DWE OR DEW and theres a red light flashing beside it when thats flashing it wont allow the movie to play what does that mean
the DEW light is a warning light. it indicates moisture on the tape. so make sure the tape is dry and in a ventelated area.
Mar 08, 2011 | Audiovox AVP7280 VCR
Dew light is on vcr and will not play tape what can I do
take a hair dryer on low setting and try to blow warm air into the vcr to warm it up until light goes out
Jun 11, 2009 | Audiovox AVP7000 VCR
Will not record
The dew warning is caused by moisture in the tape deck. LEAVING THE CAMERA OPEN FOR SEVERAL HOURS WILL SOMETIMES CURE THIS. If it does not, the dew sensor must be reset and a factory service station is the only solution. The circuit board which contains the sensor will probably need to be replaced.
Most equiptment has a standard refurbishment program and I would estimate that the cost of repair is between $150 and $200 dollars. A word of caution, never leave a tape in a camcorder as this is a magnate for moisture.
Mar 20, 2009 | JVC Video Cameras
Tape won't play
Hi hwgs,
The "DEW" warning appears if a VHS player or recorder has built up humidity. This, much like dew found on the grass on a cool morning, is the result of condensation building up, ususally after a temperature change. Once the moisture has evaporated the unit should work properly.
Be sure to keep your TV away from sources of humidity, such as a window or a bathroom/kitchen door. Also, make sure it is in a climate-controlled room away from drafts so the temperature does not change rapidly.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 21, 2008 | Zenith TVBR0922Z 9 in. Combo
AUDIOVOX VCR SER#S9AA02677 MOD#AVP7000
Hello mountain8,
It sounds like the dew sensor might be bad and giving a false reading. If you have the ability to you could disconnect the dew sensor to see if it is the problem.
I hope this helps,
Thank you
Shuttle83
Jul 15, 2008 | Televison & Video
That is 'dew' as in wet. Do you have it in a warm, dry location? This time of year they can attract condensation if the VCR is in a cold place.
Hope Ya Fix it!
Jan 06, 2008 | Audiovox AVP7000 VCR
Code F13
It's sounds like the vcr's tape mechinisum is malfunctioning to me. Try unpluging it for a while. It will correct itself. Or it might have
dew sensors if the room is too cold the vcr wont work until the dew it gone off the heads. If it don't have dew sensors
and plays the tape with dew on it might eat the tape.
also if a timer is overlaping or is set to come on right now it might do this.
Nov 11, 2007 | Panasonic NV-HD680 VCR
Sansui TV/VCR 13" color
there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape if it senses moisture in the unit because a tape will stick to the video head and get all bunged up. sometimes they go bad and will keep you from playing a tape even when there is no moisture present. if your are electronically inclined you can take the back off and locate the dew sensor, then disconnect it. the constant whirring noise is the unit's way of trying to dry off the video head cylinder. the dew sensor, which is usally located behind the video head, is a dark grey thing about a half inch by half inch and has two wires going to it.
Aug 03, 2007 | Sansui COM311AD 13 in. Combo
HELP, my panasonic keeps shutting off. Dew? condensation?
Put it in a very dry place, and let it sit for a few days. How is it getting either dew or condensation? Once dried out, keep it in an airtight plastic bag.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Audiovox AVP7200 VHS VCR Logo
294 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
