Question about NEC MultiSync LCD1735NXM (Silver, Grey) Monitor
My NEC multisync lcd1735nxm desktop display (monitor) is dark. When you initially turn it on it flashes the desktop for less than a second then goes dark. The power button stays on and if the image on the desktop is high in contrasts, I can almost see it from up close. If i turn it off and back on, I get the same result each time (it flashes on then goes dark). I have tried a different monitor on my computer and it works. I have tried my monitor on a different computer and i get the same problem. I assume the problem is with my monitor and not my computer. Is there a way to fix the monitor? Or do I have to throw it away and buy a new one?
    Top Expert:
  • NEC Master
  • 12,962 Answers
The problem is definitely with your monitor. Yes, you can have it fixed but with the price of parts and labor it is not cost effective and it will be cheaper for you to get a new unit with a warranty to boot!
Posted on Apr 08, 2017
Mark_Webber
  • 472 Answers
SOURCE: Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Posted on Apr 12, 2008
jerryg50
  • 1689 Answers
SOURCE: Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Posted on Jun 03, 2008
Rifaa
  • 99 Answers
SOURCE: nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Posted on Nov 08, 2008
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
Posted on Jul 04, 2009
budmrtn
  • 11361 Answers
SOURCE: NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 15, 2010
Hi, NEC P221 W multisync has increasinly been displaying fine vertical cyan and magenta lines, most evident on white areas and grey areas respectively.
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Jul 28, 2017 | NEC MultiSync FE950 (White) 19" CRT...
Sound not playing correctly via the speakers on the monitor Back ground music but no voice
sounds to me like you may have the monitor speakers connected to the wrong port. It typically connects to the computers Green speaker jack. If it is connected properly, look in the control panel for audio/ speaker properties, change the speaker configuration to stereo speakers, instead of 5.1 speakers. you are likely hearing the rear channel of 5 speaker setup at the moment.
Aug 29, 2010 | NEC MultiSync LCD1735NXM (Silver, Grey)...
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
OSD lockout
try holding your power button or menu button(certain cases) for 45 seconds. You must get a message saying OSD unlocked
Dec 01, 2009 | Computers & Internet
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
Multisync 1735nxm screen dosent work
Your video card may be the issue. Can you try another monitor or try this one on another PC? This will eliminate or verify the monitor.
Mar 18, 2009 | NEC MultiSync LCD1735NXM (Silver, Grey)...
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
NEC-Mitsubishi MultiSync 1735NXM
is is power related problem see the adoptor is ok or show it service center. bye
Sep 24, 2007 | NEC-Mitsubishi MultiSync 1735NXM Monitor
NEC MultiSync LCD1735NXM (Silver, Grey) Monitor Logo
73 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
