Question about HP Photosmart C6280 Printer
I have installed a new ink cartridge and it still will not print. Please help.
  • HP Master
  • 7,733 Answers
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
Streaks through the printed page
Description of Problem 100000013725
The ink is leaking out of the cartridge or ink leaked inside my machine.what should I do?
Description of Solution 200000017618
Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorizedthird party ink and/or cartridges.
If the ink cartridge is new and has not been installed into the machine, please do not install the ink cartridge. Place the ink cartridge back into the ink cartridge packaging and call the Brother Customer Service Department at 1-800-284-4329 for assistance.
If the ink cartridge has been installed into the machine and ink has leaked inside the machine, do not remove the ink cartridge from the machine.
Please contact Brother Customer Service at 1-877-Brother (1-877-276-8437) Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Jul 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
I am installing a new ink cartridge. The printer
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
CF
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 26, 2009 | Office Equipment & Supplies
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Colour Ink
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
HP Photosmart C6280 Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
