Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Problem with top dryer on stackable frigidaire
I went to start my dryer one day and it just did not start. I loaded the clothes, cleaned the lint catcher, shut the door, set the time and hit the start button. When I press the start button all you can hear is a small buzzing sound like the dryer wants to start but wont spark. Does anyone know what I could do?
  • 1 more comment
  • bibinho Jul 22, 2008
    I have the exact same problem.
  • Celivee Aug 02, 2008
    The washer and dryer were working fine and the next day I went to dry the clothes and it wouldn't start. It just stopped working! I have only had this dryer for two years and it is already giving me problems. What could be wrong with it?
  • Anonymous Mar 15, 2014
    I pulled out the lint catcher and felt something kind of catch and heard something fall into the lint catcher compartment. I emptied the lint catcher and replaced it as normal. Then, when I started the dryer, there is a horrible noise, so apparently there is something that somehow got into that compartment and then into a blower fan?? How can I get that out? (And prevent it from happening again?)
The switch may be bad or just not engaging when the door is closed. To test it you could tape something to the inside of the door right where the door meets the switch and see if it comes on. I did that and it worked. I use it as a temp. fix.
Posted on Aug 02, 2008
How do I do a hard reset of frigidaire dryer GLEQ2152ES1
Unplug it overnight. That will definitely reset it. Did you remove the cover where e the lint filter goes in. It is usually held in by two screws from the inside. There should be two wires leading to two metal strip on that cover. Make sure they are clean. You can also reach down into the lint trap to remove any more lint.
Aug 19, 2016 | Frigidaire Dryers
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
The washing machine does not filter out lint. It
I have the same problem. There's a plastic piece top back of tub that says "Clean lint filter after each load", but where is it ?
Mar 14, 2010 | Frigidaire FEX831CS Top Load Stacked...
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
Dryer drum has come loose, how do I tighten it?
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
Jun 27, 2009 | Frigidaire FEX831CS Top Load Stacked...
Someone Help! I've got something stuck in my lint filter vent!!
remove the 2 lint filter screws on the top,remove the back,you will see 4 screws on the blower box to the left(the tall box) remove the box and get that ever is stuck in it,let me know how you do-mike
Mar 18, 2009 | Kenmore Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
156 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
