Question about Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp
I have a 2005 impala and the key is stuck in the ignition and wnt come out
  • 139 Answers
Without seeing the car and from your description. You should make sure that the gear selector is in park.
Posted on Nov 11, 2010
How do I remove a key stuck in the ignition of a 2006 Chevy Impala?
KEY WILL REMAIN IN IGNITION LOCK UNTIL CAR IS IN PARK FULLY. PERHAPS THE CABLE TO THE SHIFTER IS TO BLAME
Apr 09, 2015 | 2006 Chevrolet Chevrolet Impala LT
My 2005 chevy impala won't start since someone broke into my car
i would say when the person broke into your car they set off the security system which stops the car from starting, the way to reset the security is to put your key into the ignition turn the key until all the dash lights come on and let them stay on about 15 minutes after the 15 minutes have expired turn the key off and wait about 3 seconds and then your car should start. hope this helps.
Jan 29, 2013 | 2005 Chevrolet Impala
My key will not come out of ignition when car is in park
make sure the shifter is going all the way into park did something spill into the shifter causing the cable that goes from the shifter to the ignition to stick
Apr 27, 2012 | 2005 Chevrolet Impala
Ignition switch stuck on 2001 chevy impala
sounds like stuck pins
insert key tap the end of key with malet untill it turns
once it turns drive to lock smith have them remove and repair the ignition cost will be 50 - 75 bucks verses dealer at 200 bucks
Jan 03, 2010 | 2001 Chevrolet Impala
2005 Chevy Impala ignition switch stuck in off position
Someone may have tried to steal the car and damaged the lock's internal pins. Replace the entire lock with new.
Sep 08, 2009 | 2005 Chevrolet Impala
2005 Chevy Impala key seats in ignition but will not turn
With the key in the ignition try turning the steering wheel side to side, it may require a bit of force in either direction to get the wheel freed up and allow the key to turn. This happens when you don't allow the steering wheel to come to a resting spot before removing the key from the ignition.
Apr 11, 2009 | 2005 Chevrolet Impala
Ignition Switch stuck in OFF position -Cannot Remove Key Cylinder
Yes the 2002 and 2005 are the same model and use the same lock.
2000-2005 Are all the same for anybody else needing similiar info.
Mar 30, 2009 | 2005 Chevrolet Impala
Change ignition cylinder? (lock?)
the new cylinder's key has a different code, so the anti-theft module has to reset to accept that code, with the old cylinder u could program extra keys as long as u had one key that worked, but since that is not the case with a new lock cylinder I think u are stuck with taking it to the dealer, any GM dealer can do this job, call around and try to get a lower estimate. Before having it towed try this work around I found on a car thread on this issue:
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key. Not sure this will work but it is worth a try.
Dec 15, 2008 | 2005 Chevrolet Impala
Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp Logo
220 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
