Question about Toymax Magnavox 37MF331D 37 in. LCD TV
Powers on and off all the time like a thermal switch is tripping when I put a fan behind it it stops
    Novelist:
  • 58 Answers
It may be a safety thermistor component inside tripping as it overheats just as you suspect - working like an electrical fuse, but responds to heat instead. They can go faulty and start turning the power off too soon
Another possible cause is a dry solder joint (very common problem). It's ok while cool, but after a few minutes of being on, the heat in TV causes the tiny solder break to widen just enough to switch it off.
If you can leave it on with the fan blowing on it, and it does keep going on & off without you touching it, then i'd say it's 95% certainly a thermistor.
If it turns off, and you have to turn it back on manually (it goes onto standby or off completely), then it could be either, causing the problem.
Another final thing I see as possible is, the screens inverter can be heating up and going off (the TV will stay on really, but the screen will go black as if it's off, and when cooled even slightly it can turn back on again. You can check this easily by putting a bright lamp close up to the screen. The picture will still be there, but very very dark - a flat light gently touching against the screen will allow you to just about see the TV picture.
(the screen inverter is a special high powered circuit that takes a lower voltage (usually about 12 volts) and converts into a huge amount needed to work the powerful bulbs in TV screens.
Posted on Nov 10, 2010
The fan doesn't operate. The heating coil works as does everything else. I removed the fan/ heater and put power just to the fan motor and it worked. Insert prod.# 14-N-23-079. Mdl#ZHS-23-C. 15amp
I dont know what you are working on but there is a thermal switch this turns fans on at temperature, a fuse for the fan and a relay for the fan. the sensor has 3 pins or just to on single phase motors that does not have a regulator resistor pack. 2 phase systems have a resistor pack resistor and 3 connections on the thermal switch, this is located in different places depending on your system. regulators burn out over time and thermal sensors wear out with the temperature changes over time these parts will make the fsn not work or when they in working order the fn will work. only other part to check is the earth as this wire has a lot of strain on it and weather can eat away at the earthing point. this will stop the fan working.
May 01, 2018 | Cars & Trucks
Indesit KDP60C Cooker Thermal cut in? A few days ago whilst we were cooking, there were electrical sparks visible from behind one of the controls in the top panel, and then the cooker circuit tripped out....
Not familiar with this one, but I have repaired many things like this. One of the components like a switch or relay has shorted out inside. A contact that turns the fan on has burnt shut. Sounds like you have found some info on this unit. See if there is any kind of diagram that shows what path the poser to the fan takes, and what component it passes through. That will be your culprit. The thermal switch should only activate if it gets too hot or overloaded, then it will shut the fan off.
Sep 19, 2017 | Crock Pots & Slow Cookers
I have a GE JKP45 Double Wall Oven. The upper oven stopped working after the self-clean cycle completed. There are no errors showing on the control panel. The lock circuit thermal switch located behind...
the bimetals you checked, did you remove them from the circuit before checking? if all of the thermals, not going to a fan are closed, then you have either a control problem or an element. after self cleaning usually the HIGH LIMIT thermal opens, and is a simple replacement. but if all are good then you need to look deeper. there should be an tech sheet in the control top or control panel area that can help you trouble shoot.
Feb 04, 2012 | Ovens
We have a Sanyo PLV-55whd1. We have replaced several lamp bulbs because blew shortly after we put them in. We then replaced the lamp ballast and the TV was working for a few days. Now the Power Light...
You have to pull the chassis out and it sits on top. Also there are 2 squirrel cage fans that cool the bulb, be sure to blow these out, especially the supply fan, its gets caked up really bad and then there no air to the bulb which makes the thermal switch trip. Theres also two other computer type fans a larger on which is out in the open on the right side and a smaller on on the left as viewed from the rear of the TV. The small one is burried, you will need to pull the tuner to get a good crack at it.
May 01, 2011 | Sanyo PLC XU30 Multimedia Projector
My air compressor just stopped working completely,has power to it and can turn the fan so its not seized but was gonna start by checking the reset relay and what appears to be a capaciter. just looking for...
The first thing to check is the thermal protector (circuit breaker). It is a small black button mounted on the housing on the back side of the pump motor. The unit will have to cool down before the button will reset. Usuall causes for the thermal protector to pop are: running the compressor on an extension cord, running the compressor on power lines or circuits that can't carry enough amps to run the motor, or little or no oil in the compressor causing excessive friction and heat buildup. If the thermal protector isn't tripped the next thing to check is the pressure switch. If the springs inside are broke or damaged they won't trip the switch to turn the compressor on. If the capacitor(s) are bad the motor will hum and/or try to turn but not have the power to start spinning.
Apr 27, 2011 | Hitachi EC119SA Twin-Stack Air Compressor...
My Omega oven has stopped working: single oven, air forced. The power is on, fuses intact, the timer works, the selector knob works, but when the thermostat is set the "oven on" indicator does...
The oven has a thermal trip switch behind the back wall of the oven and is under the back cover. It is attached to the back outside wall of the oven towards the top. Some thermal switches can be reset but most usually have to be changed. If you are handy you may be able to open the switch and click the little disc backwards and reassemble the switch. Make sure to refit the disc the right way around. Ensure that the power to the oven is off or the plug is pulled out before attempting to remove the back cover.
Mar 27, 2011 | Ovens
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 01, 2009 | Kenmore 63942 Dryer
GE JVM1870 Spacemaker Microwave Fan Malfunctioning when Cooking
There are two different fans in this model, as with almost all over the range microwaves.
One is the hood vent exhaust fan, which you can turn on and off at will, and which should always be on when cooking on the stove top.
This fan does not automatically come on when you cook with the microwave.
The fan which should always be on (automatically) when you are microwaving is the internal magnetron cooling fan.
If the cooling fan fails, the magnetron can overheat and the thermal cutout (TCO) / thermostat will open, killing the power to the oven. Ideally, this protects the magnetron from being destroyed.
If the thermal device is a thermostat, it will reset when it cools down, and the oven will work.
If the thermal device is a true thermal fuse, it is a one-time device and if it blows, it will have to be replaced.
If your cooling fan is bad, it needs to be replaced before using the microwave.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 16, 2008 | GE JVM1870 Microwave Oven
Toymax Magnavox 37MF331D 37 in. LCD TV Logo
96 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Steve Allison
Steve Allison
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
