Question about JBL PSW-D110 Speaker
JBL d110 /w no sound output
I recently purchased a used d110 and am getting no output out of it. Led on front stays red. If i partially remove one of the RCAs i will get a loud hum, but no results otherwise. I have tried all inputs I have available to me with no different results. Any suggestions?
Btw, the LED in front will only display red. I just noticed in an earlier post it will also display green.
  • Anonymous Oct 31, 2008
    JBL PSW-D-110Speaker
  • gcran Feb 19, 2009
    I have the exact same problem with mine
    Brigadier General:
  • 8,546 Answers
There is a standby indication that activates after 10-15 minutes without any input signal. I suspect that might be what the red light is telling you - no signal.
Loud hum from a loosened cable is normal as hum usually means there's an ungrounded connection somewhere acting as an antenna and the amp is doing its job to amplify what it thinks is a signal, in this case 60hz stray ac current is being sensed nearby. It's a good sign that you get hum from the sub because that means the amp is alive.
Avoid manipulating cable connections with the Sub or Receiver turned on as you could introduce a static spike that could harm any connected equipment.
Are you certain a bass signal is making it into the sub? The complexities of modern AV receivers vary in how you configure them to direct LFE to a sub. Bone up on that end of the chain.
Or, just hang a CD player on the Inputs of the sub and play something with a reassonable amount of Low Frequencies.
>>>> Be advised that this way of testing has NO VOLUME CONTROL because amps without volume controls always operate at maximum gain, relying on your external controls to attentuate it (hence, the loud hum from a loose cable); so choose a track that eases into the loud parts with some quiet parts up front and BE READY TO PAUSE THE PROGRAM AT ANY SIGNS OF STRESS. <<<<
A living sub will produce only muffled rumble in the absence of other speakers producing the higher frequencies which carry the intelligence of the signal. If that works, back to the receiver for settings. If not... sigh.
For hum problems, even those you cause yourself:
Disconnect all inputs to see if that helps. If it goes away start with the signal cables and add in things until it comes back.
Sometimes the reversing the orientation of the AC plug can help with hum. Or it could be something like a loose or high resistance connection internal to the sub. Good luck.
Posted on Nov 30, 2009
Subwoofer will not product sound. (ignore product)
Please verify that we're talking about a JBL PSW-D110 here. I'm making no assumptions.
Are you running the Ipod into its L & R RCA jacks as prescribed?
Have you tried it with something besides the Ipod? A sub isn't supposed to reproduce a full range signal. Come to think of it, is the Ipod even outputting anything within the sub's operational range? I don't expect a lot of real bass comes out of one.
Perhaps you could try adjusting the Low Pass up to 180 to see if anything anywhere near the 'real' bass region is present.
Bottom line: There's not a lot of need for a sub (and no other speakers) running off of any music sound source. You wouldn't hear anything above 180hz.
Nov 28, 2009 | JBL PSW-D110 Speaker
My sub has no power, ther could even be other problems i'm not aware of. so i would like to fix power first
Hiya, start by checking the power cable, then check the fuse in the unit on the pcb. If blown, replace and if it blows again then problem could be either Power supply or the amp outputs. If it doesnt blow, stays on but no sound, problem also likely to be output stage. You will need someone with experience to check outputs, etc and a meter though. Hope that helps a bit.
Best of luck
Jul 15, 2009 | JBL PSW-D110 Speaker
No output from d110
You can use a cap of same or bigger voltage,
Oct 17, 2008 | JBL PSW-D110 Speaker
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Sep 09, 2008 | JBL PSW-D110 Speaker
No output from d110
Hi Chadwik
The fact that you do get hum when you partially remove one of the RCA's would tend to say that the output stages are working ok. Is the hum "solid" and bassy, or distorted?
There are a few issues that these subs have had, mostly to do with capacitors in the power supply failing. If you are up to it, I can talk you through repairs to it.
regards
robotek
Jun 16, 2008 | JBL PSW-D110 Speaker
My JBL PSW-D110 started humming loud... The fuse is fine and the power LED displays is illuminated in green. However the sound is unbearable... It would like to replace the entire IC panel if its most cost...
Hi calsunbelt
there are some caps that fail in the power supply. If you are up to doing some electronic repairs, I could talk you through it and tell you what parts to check.
regards
robotek
Mar 25, 2008 | JBL PSW-D110 Speaker
JBL PSW-D110 Humming Loud
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
JBL PSW-D110 Speaker Logo
330 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
