Question about Vizio Televison & Video
Model VW37L HDTV 20a Picture flickers like a strobe light
  • 1039 Answers
SOURCE: FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Posted on Mar 25, 2010
alpug
  • 1961 Answers
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Posted on Jun 03, 2010
Testimonial: "Thanks again. :)"
  • 324 Answers
SOURCE: For vw37l hdtv 20a vizio t.v. The power supply
I unfortunately do not have a schematic for your set, but can give you some general information that may help.
Often these devices are either a VCR (voltage controlled resistor) or TCR (temperature controlled resistor) They are commonly used to "ramp up" power when the circuit is energized... in "old school" CRT sets, a common use was in the screen degaussing circuit. In LCD sets, they are most likely used to "fire up" the cold cathode discharge backlight tubes. They are indeed semiconductor devices and do not respond to digital meters... the input impedance is too high.You may get some sort of reading from an old Simpson 260 analog meter or something similar, but use caution because their operating voltage can damage semiconductor components. You would require a curve tracer to properly analyze the voltage ramp.
Posted on Jan 30, 2011
  • 159 Answers
SOURCE: I have a phliips hdtv lcd model 47PFL7422D/37. the
Hi, Yes unfortunately i know what it is. When repairing another make of hdtv one time, I used a different " BALLAST " for testing purposes-it was a little under powered to say the least-but i knew this-it allowed me to determine the bulbs were good. when the bulbs lit using my makeshift apparatus-HALF of the bulbs lit up lit up( dim on one side as well as some flickering! ) therefore you have a power supply that drives the backlights that is going "SOFT". Let FixYa know whatever else we can do to assist you. good luck. Prodzilla. P.S. there is a workaround you may try to give more life to this soft power supply, if able,go into menu and adjust brightness down a few notches until it evens out and stops flickering. Again good luck
Posted on Apr 02, 2011
budmrtn
  • 11361 Answers
SOURCE: I have a Digital Lifestyles
It can be bad power supply or backlight inverter board, or bad T-CON board, no way to tell unitl opening it up for details torubleshooting.
You can expect $150 and up for labor plus parts as needed, it will not be cheap!.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jun 25, 2011
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Why is my vizio tv flickering?
either inverter board fault or power supply fault!
Jun 07, 2014 | Vizio L32 32 in. LCD HDTV
Wye wont my vizio tv display anything?
that problem is usually cause of bad T-con board,,simply replacing that board can possibly fix the problem
Sep 24, 2012 | Vizio VW37L 37 in. LCD HDTV
Tv not turning on
May I know if it has a led light at the front panel? Also, please confirm if your model no. is VW37L.
Oct 04, 2011 | Vizio VW37L 37 in. LCD HDTV
I have a phliips hdtv lcd model 47PFL7422D/37. the left side of the screen is darker than the right. The screen started flickering. like a strobe light. any suggestions????
Apr 02, 2011 | Philips Televison & Video
For vw37l hdtv 20a vizio t.v. The power supply part # is DPS-201bp a rev.S1. What is the correct resistance for R805. What i read was a short on R805. Which THIS SEMI-CONDUCTOR (R805) looks like a...
Jan 30, 2011 | Vizio VW37L 37 in. LCD HDTV
Mar 25, 2010 | Televison & Video
Televison & Video Logo
157 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
