Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Replacement lamp on mitsubshi tv
Replaced the lamp now i have a red light
I have a 1080 42" Mitsubishi Projection TV - Model Number WT42311 Serial 116712. When I turn it on it comes on an then automatically shuts itself off.
Posted on Jul 23, 2008
  • Mitsubishi Master
  • 8,617 Answers
That model can have two 3300uf capacitors that go bad on the PWB which will cause the set to detect a lamp abnormality and trigger a red light on the lamp. You can find out more info on it by going to the following link and leaving them a email with your model number and symptom.
http://servicemanuals.vstore.ca/
Posted on Jun 17, 2008
I have a sony wega 2004 lcd 42" lamp light blinks red when tv is off no pic when tv is on. what does this mean?
This TV is garbage! Finally through mine out in the garbage - replaced the lamp cost from $100-300 - both lamps exploded - replaced optical block twice - lens very distorted - plain old garbage! I will never buy sony products again especially since I paid 4,000 for this tv it was new tech at the time and I was desperate for a tv - sad I am!
Jul 19, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
My Mitsubshi DLP TV has a very weak lamp that comes on but does not stay on. Is the lamp the problem?
it is very possible the lamp is the problem but the only way to know is replace it.
Average life span is about 2000 hours which for average viewer is two years.
Mar 13, 2012 | Televison & Video
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Replaced Bulb and sill have red lamp light
no you should not feel any click,the lamp plug
slides into the ballast plug in the groves.do not
force it,you could have the plug upside down or
you need to visually see if the ballast plug is
damaged.you may need to replace the ballast if you still are getting a red lamp error on the
front of the tv.
Jul 15, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Red light
Yes, If Lamp has not been replaced recently then TV need new lamp.
Let me know model number of Sony TV to provide you Lamp number and price info.
Apr 22, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Dec 12, 2008 | Televison & Video
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishe WL 82913
does the lamp indicator light as red? let me know what the status light does...is it blinking or solid give me some info and I should be able to help you also mitsubshi had some problems with jamicon capacitors with a thousand uf and above ratings that are no good 95 percent of all dlp problems can be traced to those bad capacitors
Apr 10, 2008 | Mitsubishi WL-82913 82" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
