Question about LG WM-2277HW Front Load Washer
I am a apartment maintanence man. Some people left a tromm lg wm2077cw. I wanted to help out a young couple with kids who needed a washer/dryer. This machine looks brand new and hardly used. When you program what you want and start the cycle it locks up. When its not powered up the drum spins freely. It looks to be a a machine with a history of alot of problems from what I am reading. Just trying to help out a young couple with kids. Not trying to make a buck. Thanks in advance. Dewayne Chattanooga,Tennessee
The washer doesn't start once turned on to the settings have to jam in the settings to change getting old and tired starting to hate the machine can never just turn on and run smooth is there a way to restet the settings maybe
Posted on Jul 09, 2011
  • 1,543 Answers
Change the Hall sensor, located on the motor windings (stator). Easy and cheap fix. (part is covered by a 10 year warranty) Take back cover off, remove bolt at center of rotor, remove rotor, remove bolts holding stator, unclip white Hall sensor from stator, replace sensor, reassemble. Done! That's a great machine.
Posted on Nov 10, 2010
Lg tromm wm2077cw le code
Replace "hall" sensor. Motor sensor is an easy fix and a known problem. Try appliancepartspros.com. They have video to show you how. And part.
Feb 27, 2015 | LG Washing Machines
MY LG TROMM WM2077CW WASHER DRUM WILL SPIN FOR A BIT THEN IT STARTS STUTTING AND WON'T SPIN. THANKS SCOTT
you may have stripped teeth on the motor rotor (plastic) to metal drum shaft. this is found behind rear access cover. you will need a #17 socket and breaker bar to remove rotor shaft bolt. if you have a "LE" CODE displayed, you will need a new hall sensor.
May 03, 2011 | LG WM2016C
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
Lg tromm dryer electric cooling light staying on
I started researching on here because I was having the same problems with my LG dryer. (It also happens to be the same model.) I discovered the vent hose was kinked.
With the lights, the cycle it's on that blinks. When your dryer gets to the last 5 minutes, the "Cooling" light will blink and the "Drying" light will go off. If you have the "Wrinkle" setting on after the 5 minute cooling cycle, the wrinkle cycle will start and circular lights will show where the minutes normally are displayed and the Wrinkle light will blink.
Dec 02, 2009 | LG DLE2514 Electric Dryer
Spin cycle
You have an uneven load... ( not kidding here).. If you remove and/or reposition the clothes inside . and restart.. does it spin up and complete the cycle? ( probably yes).. but if no.. please elaborate on what it does or doesn't do so we can help.. I've experienced the same problem when my daughter tries to do her entire weeks worth ( maybe longer) of clothes in one load.. The quick fix is usually to down size the amount being washed.. Hope this helps you...
Aug 29, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm soap dispencer won't open
nothing to lock it fully closed......pull harder!
Jul 21, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM-2277HW Front Load Washer Logo
165 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
