Paper jams canon pixma mp110 wont feed paper through without jamming paper. keeps telling me to reload
  • 106 Answers
If you've done alot of printing on that printer, then you're definitely in need for a maintenance kit (new rollers etc..)
Posted on Jun 17, 2008
Canon pixma mp810 keeps jamming ....the paper won't feed through the back or the front
Go to this link. In the search window in the center of the screen, type "paper jam" and click on the search button. Then select "paper is jammed inside the printer" and "removing paper jams". You will see an illustrated guide to checking all areas where paper may be jammed inside your printer.
Aug 21, 2009 | Canon Office Equipment & Supplies
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Printer keeps saying paper jam..there is no paper jam
You can also try using a rubber eraser as the rollers are going. Just take a pencil and lightly rub along the length of the rollers as they are feeding. This should remove the film that clogs the rollers surface.
Dec 21, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon pixma mp150 saying paper jam but cant see one
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Canon pixma mp110 wont feed paper through without jamming paper. keeps telling me to reload
Hello Dear,
There must be something obstructing the Auto Sheet Feed Assembly, you need to clean the paper path, use a vacuum cleaner or look deep into it if you can find something there, if the problem persists you should take your printer to the service center and get it serviced.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 17, 2008 | Office Equipment & Supplies
398 people viewed this question
jasbo
jasbo
