Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 battery problems :(
I droppped my sidekick 3 about a week and a half ago. It was a bar away from being full battery when it dropped. And when i picked it up to use it the phone side my battery was completely dead.so i began to charge it when my phone did turn back on i took the charger out to see how much longer i had for it to be full battery, but when I took it out it was already full battery. So i had just assumed that it was acting up because i had dropped it. But when i started to use it when the battery went down to about 86% percent it died and said i needed to charger it again. And ever since then i have to keep my phone on the charger at all times because it dies on 86% or so. any thing yoiu can think of to help me?
    President:
  • 625 Answers
You may need a new battery.
You can get Sidekick Batteries on ebay for about 10 dollars.
Sidekick 3 Batteries for Sale
Follow the procedure below to recalibrate the battery meter when you get it.
Try this to recalibrate the battery meter if you get a new one. This trick really only works within the first week of use. If you've used the device for 2 months already, this won't help as much (but it'll still help). Keep in mind, when I say "train the battery," I mean RECALIBRATING THE BATTERY METER:
A) I cannot stress enough that the initial charge out the box is crucial. Instructions state you should charge the device 6-8 hours upon initial start up. Most people are so geeked by getting the device that they yank it off the charger 3-4 hours later so they can go out and floss their sidekick. HUGE mistake. Despite evey urge to do so, let it charge at least 6 hours out the box.
B) Now, for the next couple of days try and let your device totally drain out it's battery before you charge it again. I've had a couple nights where I come back from work with the device already dead (Sucks for my commute, but well worth it in the long run). When you finally do plug it in, make sure it charges 4-5 hours minimum before you remove it. I usually leave them plugged in overnight...
C) You'll begin to notice an improvement in your battery life. Your device now has new "baselines" for when it's full and when it's not. Keep it up for another day or so (but don't waste an entire week doing it) and then you're set. Sometimes I would bypass the old automatic cutoff for charging by charging it while off just to make sure I "topped it off" (NOT reccomended for consistent charging, tho').
Posted on Jun 23, 2008
    Brigadier General:
  • 7,752 Answers
What you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Posted on Jun 22, 2008
What is draining my car battery?
sounds like perhaps it is time to purchase a newer car and let that one find a new home . our daughter had a problem like this and after much expense was told to unhook every thing electrical she could . ended up being the radio/stereo in the trunk.
Mar 01, 2017 | 1999 Pontiac Bonneville
Sidekick battery dies faster than usual
-- my O8 is the samee way ; thats jus how it is . mayyb u shuld try qettinq a NEW battery .
but every1 that ii know that has a O8 hass the same problem ..
ii hope thiis heLpeed <3
Oct 04, 2009 | T-Mobile Sidekick
Wont work after being droppped
Pull your battery and let it sit for a few hours.
Feb 03, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick wont turn on
corbolicous1-
Is it a sidekick ID? If you bought if from t-mobile and it hasn't got wet or been dropped then call T-mobile CC. IT should still be under warranty. Do you have a friend that has a sidekick 3 or a sidekick ID that you can try the battery from(they are the same) What type of charging cradle, one witht the spare battery charging slot? Let me know....
Jul 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 charging problems
Ok, is the sidekick 3 brand new out of the box or new to you.
The sidekick 3 has an issue with the charging port being bad.
I would contact the person who you bought it from and get a refund.
The other option is to get an external battery charger and charge the battery that way
check the link below for those
Sidekick 3 external battery charger cradle
Jun 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 wont turn on
I did the same thing with my phone. You have to replace the screen. It has been damaged.
May 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID ??Water Damage??
I had the exact same problem with my sidekick. I believe that tm is taking advantage of their customers and charging for defective phones using a phoney water damage claim. I will never sign with tm again. I am going to call the manufacturer of the sidekick-just to *****.
May 05, 2008 | Cell Phones
Sidekick 3 screen problem
This procedure usally will fix a white screen on a sidekick 3 or a sidekick ID.
http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
Try this before you replace the LCD
Dec 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Wont charge
well i suggest you take it back to the shop where you got it from they will most likely send it off to the specialists free of charge , because it is a technical problem .
The most likely reason of this problem is maybe your putting the charger in to hard and its pushing it back so its not alowing it to charge? It is quite a bad phone in that aspect
Oct 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
463 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
