Question about Lomo Oktomat 35mm Film Camera
Blank roll of film - Lomo Oktomat 35mm Film Camera
    Problem Solver:
  • 19 Answers
Two possible problems:
1. Film did not wind on. 2. Shutter not opening.
Easy to test with camera back open. Load a film and fire the shutter a few times each time with winding on, to see if film is winding correctly, at the same time you should be able notice if the shutters are firing, eight of them in succession makes a bit of noise.
Posted on Nov 11, 2010
Two rolls of film developed at CVS - apparently not exposed???
it is not unknown for film developing sites to with hold good photos so take another practice roll and have it developed somewhere else
That will prove either the camera or the developer
Apr 23, 2017 | Pentax K1000 35mm SLR Camera
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
Jan 31, 2010 | Olympus Stylus 850SW Digital Camera
Blank film
Make sure when you load your film, that the cogs are actually winding the film. Many a roll has been "shot" with the film ever advancing. If you see what your taking, that is really about all that it could be.
Jun 28, 2009 | Ricoh XR-10M 35mm SLR Camera
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
Loaded film blank
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Dec 19, 2008 | Nikon F65 35mm SLR Camera
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Char1ieJ
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Problem in camera or film roll??
Hey msenile,
It is possible that each frame would have image data imprinted without and image being exposed. This could be caused by the shutter not opening while the camera still exposing the film internally with the image data recorded. It is unlikely that this bad film since the emulsion covers the entire surface of the film and if it were bad the image data would not be recorded either. Another cause of this but very unlikely is every frame was somehow extremely underexposed. This could happen if the camera is set to manual and the light level is low and the shutter speed is set to a fast speed and the aperture is set to a very small aperture. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 18, 2008 | Nikon F80 35mm SLR Camera
Lomo Oktomat 35mm Film Camera Logo
259 people viewed this question
Top Lomo Photography Experts
Hashim Khan
Hashim Khan
Tony Parsons
Tony Parsons
Are you a Lomo Photography Expert? Answer questions, earn points and help others
