Question about Sunbeam LowProfile Space Heater
I have a sunbeam space heater model# sch 2100. wont turn on, red light keeps blinking,Is it broken or doI need to do something else to make it come on
  • 5 Answers
CAVEAT: Messing with heaters can be dangerous, so it might be better to spend 30 bucks and buy a new one!I fixed the same heater, but this might apply to other Sunbeam models. Turns out that the blinking light is the overheat sensor, so it's good that it shut off, rather than catching fire.
My unit was overheating because the blower fan motor was gummed up, and not spinning. I tried to manually spin it, but it did not turn freely. I pulled out my Electronic Contact Cleaner made by PUREtronics, though likely any decent electronics contact cleaner will do. There are screws that hold the faceplate on, including one that is covered by the base. The base removes by pulling the the hook down gently with a screwdriver, then sliding it forward.
Make sure when you spray the motor that nothing is hot, otherwise the EXTREMELY FLAMMABLE contact cleaner could ignite. Before you do this, it's a good idea to use a toothbrush or other tool to get all the fuzz off the unit. There are two long screws that hold the motor on that can be removed to give better access to all of the motor, but probably not necessary.
Good luck, and be careful.
Posted on Dec 22, 2012
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Should the red lights be flashing or be on steady
A solid light is what you actually want.
If you have a blinking light, the unit is unable to keep up with the flow of water.
Slowly turn on the hot water for your bathtub until the light starts to blink to find your limit. in other words your tankless heater is too small for your needs.
The 24 model is more for houses with showers or slower flow.
The 36 or higher model has 3 sets of heaters to be used with a bath, higher flow.
Jan 20, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
My sony kdf e50 12u wont turn on red light blinks twice
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
Jun 22, 2012 | Sony Televison & Video
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
Have heating pad model 818-7. blinking red light for high when connected- but no heat. what to do. I love this soft, terry cloth hour glass heating pad controller model number: SW204. e12107 is also on...
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
Dec 16, 2009 | Sunbeam 805810 HeatSense Heating Pad...
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Sunbeam LowProfile Space Heater Logo
1,321 people viewed this question
Top Sunbeam Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Sunbeam Pool and Spa Expert? Answer questions, earn points and help others
