Question about Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge
Y28 gas tank leaks along the seam. Probably need new tank. Can the tank be replaced? Where do I get one?
  • 293 Answers
Yes the tank can be replaced. You need to go to your lawn mower shop with your model and serial number, and the can order you one.
Posted on Nov 10, 2010
Testimonial: "I appreciate the quick response to my question. Very helpful. Thank you!"
Gas leak on the seam of plastic gas tank
Looks like time for a new tank. There are methods for "welding plastic" you might take it to a Shop that repairs raditors and gas tanks. When you take it to the shop have as little gas in it as possible. SHOPS HATE IT WHEN THEY HAVE TO REMOVE 20 GALLONS OF GAS BEFORE REMOVING THE TANK. You might check with the dealer to see if this is a common problem if its not collision damage.
GOOD LUCK. PLEASE POST AND LET US KNOW WHAT YOU END UP DOING.
IT HELPS WHEN YOU ASK THESE QUESTIONS IF YOU TELL US THE MODEL AND YEAR OF THE CAR.
Mar 30, 2015 | Mercedes-Benz C-Class Cars & Trucks
I have a gas smell in rear on ford taurus sometimes
first after your car has been sitting over night move it then look at the driveway where it had been sitting if you see fresh fuel then look under the rear of the car to see if you see any fuel dripping,if you do get your car somewhere to get a mechanic look at as soon as possible..
Jul 03, 2014 | 2002 Ford Taurus
How to fix a leaky Toro 20007 fuel tank
If the fuel tank is metal take it off and clean the seam with sandpaper and use JB weld to repair it- If plastic tank, use a glue gun.
Apr 18, 2014 | Toro Lawn Mower With Toro Power Tools
My gas tank leaks and i need to take the tank out to find it
Leaks when it's half full - could be a seam leak.
Oct 02, 2012 | 1989 Chevrolet C1500
Yard Man Gas Tank Leaking
replace the tank if you patch it and it fails when the engine is hot a fire is not worth what your trying to save try sears parts online to price it out
Mar 27, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Replace or seal gas tank
Is it a metal tank? They can be repaired easily, but probably just as cheap to buy one. By the time you go through the trouble to fix it, you could have bought a new one and had the lawn mowed. A product called POR, is a gas tank sealer and it works great.(metal only) Just follow the inst on the can and you will be all set. Hope this helps.
May 04, 2010 | Craftsman Garden
My tb425cs leaks gas when it is running. It drips from the bottom of the gas tank.
Be sure to not overfill the tank. Just load it with gas up to the bottom of the neck and be positive you're not cross-threading the cap when twisting it on. If it only leaks when operating, see if there is fuel bubbling out through the vent(s) in the top of the cap or out from under it. Also wipe the tank clean and dry to be positive it is not leaking from a seam or crack in tank or around fuel lines. If leaking from cap, might have to replace as they do have an internal rubber seal that could have gotten dry or cracked. If it's from the tank seams or fuel lines replacement may be neccessary of either one or both.
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
What does diagnostic code PO455
A code p0455 most likely means one or more of the following has happened:
  • A loose or improperly affixed gas cap
  • A non-conforming gas cap (i.e. not factory/original brand)
  • Other leak or damaged piece in EVAP system
With a p0455, the most common repair is to:
  • Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
  • Otherwise, replace the gas cap, and/or
  • Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary.
Sep 29, 2009 | 2003 Hummer H2
Husqvarna GTH2250B riding mower leaking gas tank
Hi there
The tank on that machine is a Husqvarna tank . The part # is 532 15 13-46 and you can get it @ your local Husqvarna dealer. To find a dealer near you just check the link below
http://www.husqvarna.com/us/homeowner/support/dealer-locator/ . About any recall on the tank you probably have to contact Husqvarna direct . Use "contact" on the Husqvarna site .
Hope this help
Sep 03, 2009 | Garden
Replace leaking fuel tank
Remove the filler tube. Remove the rubber fuel line and plug. Remove the attaching bolts for the tank. Place a jack under the tank with a block of wood and slowly lower the tank down. Don't forget to unplug the wiring harness too. The possibility is high that the seam is leaking. A few aftermarket companies offer the tank. Do some shopping though, prices are different with the different companies.
Jun 19, 2008 | 1966 Ford Mustang
Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge Logo
203 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
