Question about Sony VPL PX30 Multimedia Projector
Hi, I purchased a used sony vpl-px30 and the convergence is out of whack (everything has a yellow shadow). How do I adjust this?
When I turn it on fan runs and clicking noise but lamp light flashes yellownis this the bulb like to make sure before I spend that much money for one
Check with the Sony service center that serves your area. Generally when the lamp indicator flashes, it's either due to a bad lamp or the connections to it...
Nov 03, 2013 | Sony VPL PX30 Multimedia Projector
Sony vpl-px30 clicking noise on power-up, lamp will not come on
I had the Problem, I replaced the bulb and it fixed the problem.
a year ago I was not able to find this bulb under 450.00, I bought it last month from amazon for $73.00 and free shipping.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jun 17, 2012 | Sony VPL PX30 Multimedia Projector
Projector shuts down every 30 seconds. is this a bulb issue or other internal issue?
it can be one of two things
1 The Bulb need to be replaced, (do not buy from Sony, buy it from amazon for about 70.00
2 check your filter make sure you are getting enough ventilation.
Tony
Jun 16, 2012 | Sony VPL PX30 Multimedia Projector
Tv has yellow and blue shadows and is a bit wavy
you have a swollen capacitor in the power supply. try to adjust the convergence if nothing happens your convergence ic is defective.
Oct 14, 2010 | Sony KP-51WS500 51" Rear Projection...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Focus
Hi mwwill
Try using a different cable from your source.
If this doesn't solve the problem I would advise you to rather take it to a repairer as this could be either the lens that is damaged or the Mainboard where all the processing is done.
May 13, 2008 | Sony VPL CS2 Multimedia Projector
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Sony VPL PX30 Multimedia Projector Logo
77 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
Paul
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
