Question about Brother ML-100 Typewriter
My typewriter does not print. I do not have a manual or instructions for this typewriter. Is there a code I will need to insert in order for it to print...delayed or otherwise? Thank you!
  • Brother Master
  • 5,679 Answers
Check that the daisy wheel is properly installed and if the ribbon has been used up. Try pressing and holding CODE and then press Reset. (This needs to be done after the daisy wheel, correction tape or ribbon is replaced.)
The daisy wheel has a protruding ear that should be on the top right. To remove, open the cover, pull the lever towards you and lift the wheel by that ear. To reinsert, insert the wheel in the slot and press down gently. Then slide the lever forward to lock the wheel in place. Then close the cover and reset the carrier (CODE+Reset). Make sure that the ear is to the top right when you reinstall the daisy wheel.
The amount of ribbon left can be determined by looking through the viewing hole on the right hand side of the cassette when the cover is open.
The manual is available here: http://www.brother-usa.com/manuals/default.aspx?PGID=10&R3ModelID=ML100 as a PDF.
I hope this helps.
Posted on Nov 10, 2010
Instruction manual for alder tippy typewriter.
I can't find a Tippy typewriter. Alder has Tippa, Tippa 1 and Tippa S models. This site has the manuals for some Alder typewriters:http://site.xavier.edu/polt/typewriters/tw-manuals.html . The manuals are in alphabetical order and Alder models are near the top of the page. The direct link to the manual for the Tippa is http://site.xavier.edu/polt/typewriters/AdlerTippa_ManualEN.pdf .
I hope this helps.
Jul 19, 2016 | Office Equipment & Supplies
I don't know how to remove the print wheel.This is an Olympia Standard Electric typewriter, part of a word processor system. I need to order a new print wheel, but can't get the old one out. I...
Assuming this is an older oly you need the upper clear plastic portion of the printwheel case. Insert it onto the case, it unlatches the wheel.
DickyO
May 24, 2011 | Office Equipment & Supplies
I installed a new cartridge ib my Brother GX 6750 and it is not printing..The keys are working fine however it is not hitting the tape to print.
Hi!
Neat little typewriter.
Think back, and reverse the steps.
Before you removed the finished ribbon, you had to pull on a little lever that is next to the printhead, right?
Now that you inserted the new ribbon, you must push that same lever towards the platen, away from you, in order to lock it back in the normal printing position.
Please feel free to contact me if you wish.
Feb 13, 2011 | Brother GX-6750 Typewriter
Electric typewriter just aquired. Brother CE-70
Go to brotherinternational.com, click on support. Poke around in there you will find a manual for your T/W.
Dickyo
Dec 14, 2010 | Brother EM-430 Typewriter
I have no manual to the Nakajima AE-740. How do you
Go to the Nakajima distributor website at www.nadist.com/
Find your typewriter model and you'll see the instruction manual available in pdf format. Good quality and it's free.
Steve
Jan 13, 2010 | Nakajima AE-740 Typewriter
Reset code for daisy wheel
check this link on which printwheels work with your model to make sure you have the right one. There is no reset, except after you insert the printwheel and close the cover, it will automatically go to the proper position, unless there is something wrong with it.
See the instructions on page 12 of this manual:
http://www.brother.ca/en/products/pdf/manuals/GX6750-UG.pdf
Jan 18, 2009 | Brother GX-6750 Typewriter
Change my erasable tape
Here is the manual for your model typewriter, the Smith Corona Wordsmith 100 series.
Click here
This is a PDF document.
If you cannot go there by clicking the link then go to http://www.smithcorona.com and click the FREQUENT QUESTIONS link then the MANUALS link.
There are instructions in the manual that is downloadable.
Just follow the instructions for downloading the manual.
You will need adobe acrobat reader to see the manual on your computer, then you can print it out or just view it on the computer.
Dec 11, 2008 | Smith Corona Wordsmith 100 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Reprint
The first thing to do is to set the top margin. Insert the card using the SAPI semi automatic paper insertion, pilling the rt upper bail arm forward, space up or down to the top margin you want, press & hold the code key while pulling the doing SAPI the P/W will spin and reset the top margin.
Type info on card, remove card, insert next card using SAPI, Press code and reprint key and it will repeat.
DO NOT TYPE ANYTHING AFTER A SAPI OR THE REPRINT WILL CLEAR
DickyO
Jul 09, 2008 | Lexmark Wheelwriter 10 Series II...
Brother ML-100 Typewriter Logo
172 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
