My sun swith the wireless lan from the keyboard and i do not know how to turn it on again
  • 386 Answers
Hi Good day!!! if you want to turn on/off your wireless fn and f2 hope it helps you
Thank you for using FixYa
Posted on Nov 10, 2010
My wireless lan key wont turn on
Look at the device manager. Have you got a wireless network device installed?
Dec 08, 2013 | Acer 91.63X07.001 Keyboard
Wireless and Bluetooth not working running on ubuntu
Instructions
Close any open programs and files. Click "Start," "Run."
Enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Open:" box.
If your IBM T43 is running Windows Vista or 7, enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Start Search" box.
http://www.thinkwiki.org/wiki/How_to_setup_Bluetooth
Press the "Enter" key on your computer's keyboard. The Wireless LAN setup wizard will appear.
Follow the onscreen prompts to complete the Wireless LAN installation. You will be prompted when the process is complete.
5
Click "Start," "Turn Off Computer," then "Restart" to restart your computer when the Wireless LAN setup process is complete.
Tips & Warnings
If you haven't already downloaded the Wireless LAN utility to your T43 laptop, click on the "Wireless & Networking Accessories - ThinkPad T43/p" link in the Resources section. Then click on the "ThinkPad 802.11abg wireless Lan Mini PCI Adapter II" link to download the Wireless LAN utility.
Jun 07, 2012 | IBM ThinkPad T43 Notebook
My computer say my wireless is not turned on, how do I do this
Button is on the top right above the keyboard:
Button looks like a satellite dish
Wireless LAN
communication
button/indicator
Enables/disables the wireless LAN
function. Indicates the status of wireless
LAN communication.
page 5 in the User Guide:
http://support.acer.com/acerpanam/Manuals/acer/2009/UserGuides/QS_ACER_1_0_EN_AS5534.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 23, 2010 | Acer Aspire 55345410 Notebook
I can't turn on my wireless LAN. There is a button at the top of the keyboard of my Acer Aspire 4520 but when I press it, it says "wireless LAN disabled". I have tried everything to turn it back on....
Try to restore your PC to the backdated point in SYSTEM RESTORE menu in control panel. Then try to switch ON wireless again. If this step does'nt work it means your Hardware (wireless adapter) is malfunction. Replace with a new one (USB Wireless adapter)
Jan 10, 2018 | Acer Aspire 4520-5582 Notebook
Can't switch on my wireless lan in my hcl me netbook .where is the wlan swith located .
Usually the wireless switch is located on the sides of the system, if you cant see it there. In front. and if you already turn on the wireless switch and you cant still connect. Look for the function keys. Usually it would be FN and F6. When you press those two keys at the same time. You should see a pop up window. Check if the current status is on. If it is on and you cant still connect. Uninstall and reinstall the wireless driver and try to connect again. If this didn't work, you can contact your computer manufacturer or do a clean installation.
Jun 27, 2010 | Advent Netbook
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
I HAVE A MINI 10 DELL BUT I CANT SEEM TO GET THE WIRELESS STARTED TO START USING MY LAPTOP
To turn on wireless, with the computer
turned on:
1. Press <Fn><F2> or press the key on the
keyboard.
The Wireless Enable/Disable dialog box
appears.
2. Select one of the following:
––Enable Bluetooth
––Enable Wireless LAN
3. Click OK.
To turn off wireless, press <Fn><F2> again to
turn off all radios.
-Dell mini User Guide Page 9-
Jun 26, 2009 | HP 2133 Notebook PC
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
    Important! Use care to prevent damaging the keyboard ribbon cable.
May 17, 2009 | HP Computers & Internet
Wireless Button Disabled
After one month of trying everything, I finally figured this one out.  First turn off and restart your computer.  Then press F10 to enter the System BIOS Settings.  Select F9 (Setup Defaults) and when it asks Load Default Configuration Now? , Enter YES.  Then, press F10 (Save and Exit) and when it asks Save Configuration Changes And Exit Now, Enter YES.  This should restore the wireless LAN button to its original factory settings.  Once you restart the computer the button will be listed as disabled, but press on the button and it should work again.  I hope this helps someone else out!
Sep 29, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
David Payne
David Payne
