Question about Casablanca Fan 3245T Ceiling
My inteli-touch casablanca fan won't turn on at all (light or fan). Today there was an interruption of electrical power to the house and now the fan won't work. I know there is a way to "reset" the switch but I can't find those directions anywhere....
  • 4 Answers
I have had 3 casablanca intellitouch fans stop working. All 3 had the same problem. The 1000uf/35vdc capacitor failed. Replaced with 1000uf/50VDC cap from Radio Shack. No problems since.
Posted on Feb 25, 2018
  • Al Treftz Feb 25, 2018
  • Peter Kim
    Peter Kim Jul 28, 2018
    This was an excellent insight. I took my Casablanca (W32 controller type I think) apart and immediately noticed that the 1000uF(25v) valued capacitor was bulged out. I knew that there was a good chance that replacing it would fix the issue I have. Once I desoldered the old capacitor, I measured the capacitance and ESR using this - https://www.banggood.com/LCR-T4-Mega328-... You can also use a generic multimeter to test the capacitance, but ESR is a much better measure of capacitor malfunction/degradation. The capacitance was like 90uF and ESR was like 11-ohms. On a new electrolytic capacitor, it should be in the order of ~1000uF and 0.15-ohm ESR. With the replacement the fan worked perfectly! Much cheaper than upgrading the control module for $150~$175. Thanks! (Where did you find the Radio Shack? They are extinct as far as I know)
SOURCE: Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Posted on Aug 05, 2010
SOURCE: Casablanca fan is not working!!
The controler board has gone out due to either a power surge, overheating or too much wattage in the lamps. There are two types of of controlers and both are subject to this kind of failure. Here's a troubleshooting link
http://www.lampdepot.com/service/intellitouch.htm
Posted on Jul 09, 2008
  • 70 Answers
SOURCE: Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Posted on Jul 25, 2008
MN_Jack76
  • 45 Answers
SOURCE: our casablanca ceiling fan has
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Posted on Feb 06, 2009
  • 57 Answers
SOURCE: Casablanca Intellitouch Fan was working fine..
Sounds like either the IT wall switch has malfunctioned, OR the IT board inside of the fan has shorted out. This is actually a fairly rare problem with the boards and you may get it covered under warranty. Try calling Casablanca. This fan is worth repairing rather than buying a new one.
Posted on Jun 10, 2010
How do I op beeping of my Casablanca stealth fan Bulb is burnt and I removed he burnt bulb. would not top annoying beeping
Replace the bulb. If you are going crazy while getting a new bulb turn off the breaker for the room. A serious design flaw, I would complain to Casablanca if you have the time.
Oct 05, 2014 | Casablanca Fans Casablanca Contemporary...
I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
Jul 10, 2012 | Casablanca Fan Dryers
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
When the Casablanca fan remote control wall button is pushed the fan beeps and progresses to the fastest fan speed and stays there. How do I adjust the fan to be able to vary the fan speed so I don't have...
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
Dec 01, 2010 | Casablanca Fan Dryers
I have a Casablanca Panama fan with Intellitouch wall control (W-32). The control correctly turns on and off the lights, but when the button for the fan is touched, the fan makes a quick noise (like the...
There are different parts that might became bad and cause your problem like relay contact, starting capacitor, running capacitor. However all these parts are included in one unit the PCB printed circuit board or electronic board? So you need to replace this parts in attached link is also called RMM.
We have here below a link with service manual for the fan at which on the bottom you will find the parts diagram and parts list. You should try to confirm the part code for your model with Casablanca service department before confirmation of order.
Also please note that you will need a little experience with electronics before proceeding with above operation.
http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ConversionKit.pdf
Oct 31, 2010 | Casablanca Fan Panama II 50" Ceiling
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
I have a 25 year old Casablanca Intel--touch that quit working about the same time we had a power surge that knocked out our DVD. No fan or light. I had the original switch and was able to obtain a W-32...
Sounds like the board fried, the early IT board is very sensitive to power surges unfortunately and it's surprising it still worked as long as it did. This fan would be from approximately 1985, so it should have the RMM-1 board which can do "Flik" mode without the control. As a test, remove the light, and unplug the Light Drive Module in the switch housing, and then apply power. The fan, if it is going to work, will start on low and work it's way up to high. If the fan board is indeed fried, it will do nothing. You may be able to get re-imbursement for replacing the board from your power company, or to replace the entire fan with another IT unit.
www.casablancafanrepair.com for more info.
Sep 13, 2010 | Casablanca Fan Dryers
I have a Casablanca Intelli touch ceiling fan. The remote is a simple toggle switch, turn in on, listen to the beeps, off an on quickly to set it. How do I reverse direction on this fan?
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Apr 01, 2010 | Casablanca Fan 3245T Ceiling
Casablanca ceiling fan lights flicker out
here is solution for you.
instead of put all Fluorescent light bulb, put one incandescent bulb.
Dont' ask why but it works. (use 60w or above)
Mar 15, 2009 | Dryers
Casablanca Fan 3245T Ceiling Logo
5,011 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
