Question about Microwave Ovens
Have ge spacemaker xl micowave--model jvm 1653.......has always worked without a flaw--------now most every morning as attempting to use--starts and then instantlly quits----xxxxxxx across read-out --and then tells you to set clock-month day etc,--------try to start and xxxxxx apers again and again--resetting clock etc------then works all day with no problems........next morning same old--same old--------help
    Sergeant:
  • Microwave Ovens Expert
  • 224 Answers
Your losing power to the unit. Bad breaker or bad outlet. Loose wire at breaker or outlet. when you run it and it gets a little hot the connection expands and makes better contact, and that is why it works through out the day and then quits after it sits for a while, then is coos and contracts again.
Posted on Aug 24, 2017
MicrowaveSvc
  • 9098 Answers
SOURCE: ge jvm 1653 won't heat
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Oct 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: oven not heating.
I would say that one is a bad door switch (bottom one) or a bad door switch mount.
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
  • 9 Answers
SOURCE: Microwave runs but does not heat
could be door switches could be pcb could be mag, cap or hv transformer.. Its really just a guessing game but one of the above is defo the cause best to get a tech in to have a look or get it replaced whichevers best for yourself
Posted on Nov 13, 2008
  • 1214 Answers
You've got a problem in the microwave circuit, which could be one or more of the following components -
1) HV diode
2) HV Capacitor
3) HV transformer
4) Magnetron
I am leaning to the diode, but it would take further investigation to determine for sure. Diodes are cheap, as if the capacitor, and replacing those first would not necessarily be in vain if it turns out to be the transformer or magnetron. And I would be most inclined to say it's the magnetron before I would think transformer.
Reply back what you find or if you have more questions.
Posted on Feb 04, 2009
My microwave just stopped working it does'nt do
do you know why did it not work ?you check it .and you can take it to fix .
home light bulbs
May 03, 2012 | GE Microwave Ovens
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker - JVM 1653 SH unit shuts down after power up. Start back again when cool? Do I scrap it or is it repairable?
For most microwave problems it will cost more then is practical to make repairs to them...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 19, 2010 | GE JVM1650 1000 Watts Microwave Oven
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 02, 2010 | GE JVM1440 Microwave Oven
Our GE JVM 1653 spacemaker microwave looks like it is working but the food doesn't heat up. It lights up and goes around but no heat? Whats up?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
ysss
Jul 06, 2010 | GE JVM1653 Microwave Oven
Microwave oven runs but does not heat food
heatman101
ftsd
Jun 22, 2010 | GE JVM3670 Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm 1653 won't heat
1) HV diode
2) HV Capacitor
3) HV transformer
4) Magnetron
Feb 04, 2009 | GE Microwave Ovens
Nov 02, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
149 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
