Question about Panasonic KX-T7730 Corded Phone
Can not enter program mode to change display time
  • Panasonic Master
  • 2,460 Answers
In a TA series system there is exactly one phone that can do it. The phone is ext 101 or connected to jack 01 in the sytsem. No other phone can do it.
Carl
Posted on Nov 10, 2010
  • Carl Navarro
    Carl Navarro Nov 14, 2010
    Thanks for the low rating. Now go look for the Panasonic SYSTEM and post back. I guarantee that there is one phone that will get you into programming. You just have to be able to help yourself and know what system you have.
I need NOMA N1508 manual.
answer 1 Function and operation
1 - This timer has 3 working modes
a - Auto Mode(AU)
b - Auto and Temperature Control Mode (AC)
c - Manual Mode (LL)
Press "MODE" button and the LED display will cycle through these three modes.
2 - There is an output indicator light which turns Green (On all modes) and red (Off - manual mode)
3 - There is a bettery backup that can retain programs for about 1 week after power outage.
Operation
1 - On first use . Connect the unit to 125V AC power source. The LED display blinks 'C'. The unit at this moment is in initial state, where time and program need to be set.
2 - Press the "TIME" button, the LED display will now show "12.00", now the unit is entering time setting mode
a - The time interval for this product is 15 minutes
b - Press "TIME" button again. LED dislays 12:15 with each press of the time button the time increases by 15 minutes. If you press and hold the time button for 2 seconds the LED will increase rapidly.
c - After setting the time, press the enter button and the LED will display current time setting.
d - To change the clock press the "Enter" and the "TIME" buttons simultanously to enter the editing mode. Press the "TIME" button to adjust the time. Press the enter button to confirm
3 - To program press "mode" button once and the LED will display "AU" which stands for Auto Mode, press the "MODE" button once again and the LED will display "AC" which is the Auto and Temperature Control Mode. Press the "MODE" button once more and the LED will display "LL" which is Manual Mode. Press enter to confirm the selected mode. Press "MODE" button to role over these three options.
a - Auto Mode
Press "MODE" button and the unit will enter Auto Mode, LED displays "AU"
- Press "ENTER" button to confirm. LED displays "P". Press "TIME" button to set program ON time.
- After the program ON time is set press "ENTER" button to enter program ending time. LED will display "E". Press the "TIME" button to set the ending time.
- Press "ENTER" button to return to normal time display mode.
- The program indicator will be turned on after the ON time and ending time have been programmed
- Press the "TIME" button to review the program ON time setting and program ending time setting. The LED displays "P" and "E" respectively. After that the LED displays the current time.
- In case you want to modify the setting repeat step "a".
*** Note: When entering your program if no action takes place within 15 seconds it will go back to the time screen.
Press the "MODE" button and the LED will display "AU". Press the "MODE" button again and the LED will display "AC". press the "ENTER" button to confirm.
- The timer activates the load only when the folloewing two conditions are met:
1 The temperature is below -10
2 The program on time p is reached
For instructionsn on how to set the program ON time and the program ending time please refer to the Auto Mode fucntion
- The program indicator will be turned on after the ON time and the ending time have been programmed.
- When the program ending time is not yet reached, the load will be deactivated if the temperature rises above -7 and will be activated again if the temperature drops below -10. Once the prgram ending time is reached the load will be deactivated regardless of the temperature.
C - Manual Mode
Press the "MODE" button to select Manual Mode. When the LED displays "LL" press the "ENTER" to confim. The LED returns to show the current time. Press the "TIME" button to activate the timer the LEd will display ON. Press the "TIME" button again the LED will display off.
- In Manual Mode the output indicator will display red when the load is deactivated and green when activated.
- To exit manual mode press "TIME" and "MODE" buttons simultanously and the unit will return to Auto mode. The loading will be activated and deavtivated according to the previous setting.
4 Output indicator
1 - In Auto Mode ort Auto Temperature Control Mode when the loadind is deactivated the output indicator tunrs off.
2 - In Manual mode the outpur indicator turns red when loading is deactivated.
3 - In Manual Mode, Auto Mode and Auto Temperature Control Mode the output indicator turns green when the output is activated.
To reset all of your settigns including current time and programs, press and hold the "ENTER" button for 5 seconds from the "TIME" mode. answered 3 weeks, 2 days ago by Anonymous
Jan 11, 2011 | Sport & Outdoor - Others
Tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 | Lands Phones
How do I change the date and time on my Meridian Business Set M5316?
To Change the Date and Time:
  1. Press
  2. Press the volume key until "Time and Date Set?" is shown on the display
  3. Press
  4. Enter the date using the format shown on the display (DDMMYY)
  5. Enter the current time based on the 24-hour clock
  6. Press to save the new time and date settings
  7. Press or to exit the programming mode
To Change the Display Fomat:
  1. Press
  2. Press the volume key until "Time and Date Format?" is shown on the display
  3. Press
  4. Press the volume key until the desired format is shown on the display
  5. Press to save the new setting
  6. Press or to exit the programming mode
Nov 16, 2010 | Cell Phones
How do you change the time on the display for the M7208?
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316. The 4 top line/feature keys are now used for programming.
the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Nov 09, 2010 | Nortel Meridian M7208 Corded Phone
Want to change the time
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Nov 08, 2010 | NorStar T7316E Corded Phone
How to set the time and date
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Oct 25, 2010 | Nortel T7316E 2-Line Corded Phone
Change time and date on Norstar M7324
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Oct 25, 2010 | NorStar M7324 Telephone
How do you change the time on the phones. Since Daylight Savings time My clock is off by an hour
How do I change the Time and Date on a Merlin Legend system?
To change either the Date or the Time on the Legend system, you must program it from the main System Programming console (MLX-20L). This will change the Time or Date on all the display phones throughout the system, except the ATL (Analog) display sets. These phones must be programmed on each individual set.
How to change the Date in the Legend system:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit.
  4. Press System.
  5. Press Date.
  6. Enter date in following format: mmddyy (where MM is the month, DD is the day, and YY is the year).
  7. Press Enter.
  8. Press Exit.
  9. Press Home to exit programming mode.
How to change the Time in the Legend system:
  1. Press Menu.
  3. Press Exit
  4. Press System.
  5. Press Time.
  6. Enter the time in military/24 hour format: HH:MM (where HH is the hour, 01-24, and MM is minutes, 00-60).
  7. Press Enter.
  8. Press Exit
Nov 04, 2009 | Lucent Merlin Legend MLX-20L Phone
How do i change the time on a norstar m7208 phone
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4" 2.- Enter password (default = 266344) - display should read "Terminals & Sets" 3.- Press "NEXT" 5 times - display should read "Time and Date" 4.- Press "SHOW" - display should read "Hour:___" 5.- Press softkey "CHANGE" 6.- Enter hour - display should read "AM OK or Change" 7.- Select AM or PM 8.- Press "NEXT" - display should read "Minutes:___" 9.- Press softkey "CHANGE" 10.- Enter minutes 11.- Press "NEXT" - display should read "Year:___" 12.- Press softkey "CHANGE" 13.- Enter year 14.- Press "NEXT" - display should read "Month:___" 15.- Press softkey "CHANGE" 16.- Enter month 17.- Press "NEXT" - display should read "Day:___" 18.- Press softkey "CHANGE" 19.- Enter day 20.- Press "NEXT"
Nov 01, 2009 | NorStar M7310 Corded Phone
How do I change the date on the Lucent D18 Phone?
Some advice from the Avaya support web site: How do I program System Time? To program the System Time on Basic Partner Release 4.1:
This System Programming procedure sets the time that appears on system display phones.
Enter the time in 24-hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2359 (11:59 p.m.). Since each time must have four digits, use leading zeros when necessary. For example, to set the time to 9:00 a.m., enter 0900. For 4:45 p.m., enter 1645.
The time appears on system display phones as a.m. or p.m. (not in 24-hour notation).
To change the System Time using a display phone at extension 10 or 11:
Press Feature 00. Press System Program (Left Intercom button). Press System Program (Left Intercom button). Press # 103. Enter the time in 24-hour notation. For example, to set the time to 2:15p.m., press 1415. A display similar to the following appears:
System Time Data 1415 Note: The time will appear on system display phones as 2:15p.
Select another procedure or press Feature 00 to exit programming mode.
Mar 09, 2009 | Lucent PARTNER18 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
59 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
