Installed new printer cartridge for hp deskjet 9800 all lights are blinking in a rotating fashion and i can't turn the printer off unless I unplug it and I cant eject the newly installed cartridges manually
I replace a new cartridge hp deskjet 9800,the power button keep flashing,even so i .......?
Posted on Oct 14, 2008
I replace a new cartridge hp deskjet 9800,the power button keep flashing.......?
SOURCE:
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
The two red lights on the left hand side of the printer are blinking? What does that mean?
If you mean the ink cartridge lights, when they are blinking and the power light is on, it indicates both cartridges are damaged, missing or improperly installed. Take the cartridges out and reinstall them. Replace them if the problem persists. A full list of the codes is in the manual:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00458223/c00458223.pdf
I hope this helps.
Feb 18, 2010 | HP DeskJet 9800 InkJet Printer
My Deskjet 9800 has both cartridge lights flashing. I've put in new cartridges and ensured that they are properly seated. I cannot print a test page.
you will need to replace the carriage assembly because the cartridge has punched a small hole in the circuit contact board, which broke the circuit
Feb 06, 2010 | HP DeskJet 9800 InkJet Printer
HP Deskjet 9800 Printer does not recognizes the cartridge and red light blinks even when the HP 97 (right cartridge) is installed. I have cleaned the contact area with Swab/alcohol but still it does not...
Take out the cartridge and examine the wire ribbon in the cartridge assembly. Many HP DeskJet 9800 users reported the ribbons getting damaged/punctured while installing or removing ink cartridges.
If that's the case your solution is to order part #C8165-67061 (google it) and install the entire assembly yourself. Be prepared that these items are delicate and some common sense is required.
You can also take the printer in for service to your local "big-box-electronic" store. This might not be cost effective so make sure you do your homework.
Jul 21, 2009 | HP DeskJet 9800 InkJet Printer
Printer does not see the cartridge
mine did that a year ago try to reseat the cartridge take it completely out and place it back in
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Installed new tricolor cartridge and getting message that wrong cartridge is installed
Remove cartridge and verify it is the correct type, and all pieces of tape have been removed. Replace cartridge... it isn't seated until there is a gentle snap into place.
Jun 03, 2009 | HP DeskJet 9800 InkJet Printer
Lights flash on HP deskjet 6127
from what I read on line at HP forums unplugging the network cable may fix it. Others sat they had to buy a new printer
HP DJ 6127 after change of the cartridge blink lights nothing else happens
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
Hp deskjet 3940 printer light just blinks.It will not do anything else.
in this printer only one LED present that blinks and two kinds of blinking one slow and other fast blinking
So if slow blinking inyour printer then this may be cartridge error, if you are are using refilled ink cartridge so please change change that one.
and if fast blinking in your printer then you cannot do anything.
in last go to AN Authorised service centre(to know the address of AN Authorised service centre in your city please visit at http://www.hp.com ).
thanks
ttyagi
Jan 09, 2009 | HP DeskJet 3940 InkJet Photo Printer
Hp deskjet 9800
i had the same problem -- this is what finally worked for me. turn the printer off, wait several seconds, then turn it back on. when i first turn it on, the ink lights and the resume lights blink a few times. as soon as that stops, before the ink cradle or any other parts move, lift the lid. the black piece in front of the ink cartridges will drop down so that the cartridges can be changed.
Apr 01, 2008 | HP DeskJet 9800 InkJet Printer
579 people viewed this question
k24674
Marvin
Marvin
