Question about SharpVision XV-Z10000U Multimedia Projector
I have a sharp projector model 10,000 in my attic in another state will it do hdmi or component only
2 Suggested Answers
SOURCE: Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Posted on Feb 02, 2009
What might be the problem since my macbook pro is connected to the projector through a HDMI to VGA adapter, yet the screen remains black?
Vga and hdmi are different formats. Unless you are using a coverter box that translates the data from one format to another it won't work. Vga is analog and hdmi is digital
Oct 08, 2016 | Sharp Office Equipment & Supplies
How do I get a signal between my DirecTV receiver and my height a chi CP - X 885 multimedia projector using component cables?
Not familiar with your Directv receiver, but if there's component output then just straight connect to the component input of the projector. Make sure the output setting of the receiver is set to 1080i, as it's the highest resolution the projector will recognize. If only HDMI out if available, then you'll need a down-convertor (HDMI-to-Component). Something similar to this, http://www.walmart.com/ip/HDMI-to-Component-Audio-Cnvrtr/43096325
Aug 01, 2015 | Office Equipment & Supplies
Hooking up projector to laptop with only HDMI port
The PG-F320W has a DVI-I port between the VGA/Component input and the VGA output. You will need an HDMI to DVI cable or a HDMI to DVI adapter and either an HDMI or a DVI cable. If you use the audio input of the projector, you will also need the audio cable between the computer and the projector. (Make sure to disable the HDMI as the audio playback device. In Windows, go to the Hardware and Sound Control Panel. Then go down to Sound and Manage Audio Devices. Click on the Playback tab and check your output device. Click on Start for Windows 7 and earlier, Windows Key + X for Windows 8. Then select Control Panel.)
Monoprice.com has good prices for most cables. The HDMI to DVI cables are here: http://www.monoprice.com/Category?c_id=102&cp_id=10231 .
The manual for the PG-F320W is available here: http://www.sharp-world.com/products/data_projector/pgf320w/pdf/PGF320W_ex1_en.pdf . See page 21 for the DVI cable connection information. See page 61 for video resolutions that the projector can handle.
I hope this helps.
Dec 13, 2013 | Sharp PG-F320W Projector
Optoma hd65- componant signal OK but no hdmi signal found
whats the reason for no display on hdmi to hdmi connection- to the x box display is fine-?
Jun 25, 2012 | Optoma HD65 DLP Projector
Hi i want to connect a tv to my optoma hd 66 projector
hi,
You can't be able to connect a tv to your projector, because it doesn't have a monitor out.
There is only one way. If the source is a DVD player then connect the its HDMI output to the projector and the component video out to the tv. You can't be able to get video out from the composite video output of your DVD player, when you are using HDMI. When plug the HDMI it will switch off the composite video out. The component video out remain ON whether you connect HDMI or not.
ok
Mar 31, 2011 | Optoma HD72 Multimedia Projector
Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Dec 30, 2009 | Denon AVR-1603 Receiver
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
Mitsu x400bu gives coprright indication when i go from hdmi todvi
Firmware update, yes or use component video. HDMI has embedded copy protect and is really an aggravating connection. Consider this, hdmi's benefit is embedded audio, your projector does not need this. Component video will meet you needs because the projector is not real high on res. Good luck
Mar 24, 2009 | NEC Mitsubishi LVP X400BU Multimedia...
No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
How do i connect my projecter with my pc
Your Sharp XR-10X will only allow video inputs through the:
1. RGB/ component input (15-pin HD)
2. composite video input (RCA phono color yellow)
2. S-Video input ( 4 pin mini-DIN )
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output (4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Good luck and kind regards.
Dec 03, 2007 | Sharp XR-10X Multimedia Projector
SharpVision XV-Z10000U Multimedia Projector Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
