Question about Disney DTD1363-CAR 13" TV/DVD
Cars tv anyone know any solutions to cars tv being fixed or recalls?tv will not stay on also when does turn shuts of 5 min later and vol and channle go up by itself
  • Anonymous Aug 03, 2008
    I'm having the same problem with it not staying on It is a 110 outlet but stays on10 minutes and goes off
  • mike-e-mike Aug 15, 2008
    I have the same problem and my son is TRIPPIN!!!
    Please help!
Ok I'm looking at the owners manual and it says that if you tv is plugged in to a higher voltage outlet in my turn its self off as a fire safty switch. So check to see if the plug in is a 210 outlet if so thats your problem otherwise it doesnt show anything else about it turning off hope that helps!
Posted on Jul 18, 2008
Imaginext Batcave drawbridge won't go all the way up.
Turn the batcave over and remove the long black piece in the center section (5 screws). Re-align the two white gears so that the drawbridge stays shut. Then put everything back together. Easy 2 min. fix.
Jan 06, 2013 | Fisher Price Imaginext DC Super Friends...
JVC HD-52Z575 red screen
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
Feb 20, 2010 | JVC HD-52Z575 52" Rear Projection...
How do I reset the metter for a new lamp?
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 06, 2009 | Panasonic PT-52LCX66 Projection Television
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv shuts off for awhile then i can turn it back on immediately
hitachi is known for its problems and the best solution is to call a repairman out to repair it properly.i know thats not much help but its the only sure way to fix it and fix it right
Jan 21, 2009 | Televison & Video
Wont stay on.
The only way you can fix this is you have the proper tools and have very good soldering skills. If so, I will post more instructions on how to fix this.
It has a blown channel, it can not be fixed without some good troubleshooting skills. The protect mode is so you don't cause more damage to it. If you continue to turn it on, you may cause more damage.
Your best bet is to take it in to get repaired at a service center.
Let me know if you require more help,
Dave
Jul 01, 2008 | Harman Kardon AVR 235 Receiver
Flat battery
Sounds like the timing unit which automatically turns off your dome lights after a few minutes is working backwards. Probably need a new unit.
Jun 02, 2008 | 2006 Mazda Tribute
PROBLEM WITH SAMSUNG DLP TV
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Disney DTD1363-CAR 13" TV/DVD Logo
134 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
