Question about Brookstone SmartSet Alarm Clock
I have a small display clock that is clear glass and you touch the top and it will show you the time, press it again temperature, then date, then timer. On the bottom the only buttos are set and then up and down and alarm. There is also a Return to Time switch (on or off). How do I get the time to be in 12-hour and not military. Thank you.
4 Suggested Answers
SOURCE: Alarm doesn't work
I finally figured it out. I was setting the alarm for p.m., which isn't labeled such, instead of a.m., which is labeled. For example, the alarm might read "8:00", but that actually means 8:00 p.m.
Posted on Dec 21, 2009
BillB-SA
  • 2761 Answers
SOURCE: daylight savings time changes at wrong date
The DST schedule is hardwired into the older clocks and cannot be modified to run on the new schedule. If the clock has a DST switch, you can can turn it OFF and reset the clock only twice a year. On my old "ATOMIC" clock, I've set the DST function OFF, and I use the time zone switch for my adjustments. Sorry, but your only other choice is a new clock.
Bill B
Posted on Apr 05, 2010
SOURCE: I have the smart alarm clock model number 4511.
Open the door on the bottom of the clock. There's a switch there that unlocks the time setting function. After you unlock it, you can use the < and > buttons on the top of the clock to move the time back or ahead. Use the "mode" button to select between time and alarm setting functions.
Posted on Dec 12, 2011
Stove clok is not showing time
try pressing the clock button after setting the clock .^-^
Mar 09, 2015 | Kenmore Kitchen Ranges
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
How do you reset the clock on the microwave
press clear, press clock, enter time, press clock again.
Dec 09, 2009 | Microwave Ovens
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
How to set date and time on Canon FAX-L350
Maek sure machine is switched on and there is a display showing.
1. Open the 'one-touch' speed dial panel (plastic flap to right of main number keys)
2.Press the key 'data registration' The display will show "REGISTRATION 1. DATA REGISTRATION"
3. Press 'Set' key twice (lower right key on grey centre panel area). The display will show "DATA REGISTRATION 1. USER SETTINGS" after the first key press, then "USER SETTINGS 1. DATE & TIME" after the second key press.
4. Press 'Set' again, then use the numeric buttons to type in the correct date and time - you should get something like 11/01 2009 and 16:09 in the display (use 24 hr clock for the time).
5.Press 'Set' to save the date and time the display will show "USER SETTINGS 2. UNIT TELEPHONE #"
6. Press the 'Stop' key to return tot he machine's normal 'standby mode' .
7. Print off this webpage so that you can remember how to change the time for daylight saving time changes etc... or int hee vent of a power cut.
Hope this helps.
Aug 12, 2008 | Canon FAX-L350 Plain Paper Laser
Unable to set the time correctly
Try to set it again:
1/Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2/Move the field highlight to the OFFSET field
and press Enter
3/With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4/Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
5. Press QUIT , to return to the MENU Page, then select
Navigation Setup “NAV SETUP” with the Up & Down arrows (↑↓)
then press ENTER
Hope that helps.......
Jul 02, 2008 | GPS
Westclox Travel Alarm
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Jun 30, 2008 | Audio Players & Recorders
Manual Information/Owner Guide
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
FixerUpper
Feb 02, 2008 | SkyScan 86709 Atomic Wall Clock
41 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
