My problem is trying to install i-tunes on windows 7 after the download and you click on run a box pops up tells me this installation package could not be opened. verify that the package exists and that you can access it, or contact the app vendor to verify that this is a valid windows installer package. no help from last teck was told to unindtall windows installer pack under remove programs it does not show it in programs and features ther are three icons one says macrosoft corporation product version 15.4 the 2cd icon shows microsoft corp product version size 5.57 mb the 3ed shows microsoft corp product version 2.78 mb............. could really use some help or will have to bring it in 100 miles round trip HELP.
  • 4 more comments
  • douglas752 Nov 10, 2010
    can not find windows installer anywere in the add or remove control panel but after typeing in a command to see if its working and on it is should i still try downloading your link
    hey also on the link will that work with windows 7 has info about xp witch i have had for years just started using win`s 7
    hey again i see that the download is for win`s7 but um not shur witch one out of the seven to chose from i know it not thr xp but what other one is the right one
    ok i think the file i need to download is version 4.5 windows6.0-KB942288-v2-ia64msu or is it windows6.0-KB942288-v2-x64.msu could you please tell me
    so i can not find where to uninstall windows installer if i install the 4.5 installer will it install over the old program this is NUTS
    willing to pay more to get this fixed now!
    Guru:
  • 2,178 Answers
You have to have the Windows Installer in your computer. If you can't see it listed under the remove programs, then it's not in your computer. Here's a links: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=889482fc-5f56-4a38-b838-de776fd4138c
Posted on Nov 10, 2010
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
Upgrading windows vista 64bit
Did you download your Win7 upgrade or did you buy a boxed copy? If you have a boxed version, check in the box. My Win7 upgrade came with both the 32-bit and the 64-bit DVDs in the box. Try using the other optical disk in the upgrade package. If only one disc is in the package, contact the source where you got the upgrade. Only the package for installing a new OS (OEM or full version) comes with just the one disc included. For those, you need to specify the type of system on ordering.
If you downloaded the upgrade, you will need to get a different upgrade file and burn it to disc or make a USB installer for that version of Windows 7.
To confirm your current version of Windows, click Start and choose the Control Panel. Click on System and Security and then on System. This page will display the Windows version and append x64 if you have the 64-bit version.
Alternatively, download the Windows 7 Upgrade Advisor, http://windows.microsoft.com/en-us/windows/downloads/upgrade-advisor , and it will confirm if your system is compatible with Windows 7 and which version you need.
I hope this helps.
(even the Windows 8 upgrade came with both the 32-bit and 64-bit DVDs in the box.)
Jan 05, 2014 | Toshiba Satellite Computers & Internet
Micrografx creatacard 3 gold - repeat only micrografx, not american greetings
Micrografx Creatacard Gold 3 was created back in the Windows 98 days and most likely the installer is a 16-bit installer. Windows XP worked OK with 16-bit installers, but Vista, Windows 7 and Windows 8, 8.1 will not work. There is a work-around I found ( I actually found this fix for installing Photoshop 7 under Windows 7) and it works! I was able to install Photoshop 7.0.1 under Windows 7 Pro x64 edition and it works great!
Perform a search for Install-Photoshop-6-or-7-on-Windows-7 or go to this website http://www.wikihow.com/Install-Photoshop-6-or-7-on-Windows-7. Under this website, Look at Method 3 of 3 .
Stuff you will need:
1. A working Windows XP -SP3 system where you can install the Free Scalable Smart Package. You may be asking why? You will need to install the Micrografx Creatacard Gold 3 on this system with the "Discovery Program" running so it can create a new 32-bit installer
2. A CD-RW or a Memory Stick where you can copy the new .MSI file created and run it from Windows 7 x86 or x64 bit system.
3. Download the Free Scalable SmartPackager program. This used to be called WinInstall LE but they have since changed the name. You can find the program here http://www.scalable.com/smart-packager-ce-msi-package/. This is Free, but you still need to register to get the software. The latest version as of last week is v2.0.2.
4. Printed out instructions from the website so you can follow along. Once you perform this, you may end up trying this for other "older" software as well.
Basic Overview:
1. Under your Windows XP - SP3 system, install the Packaging software called Scalable SmartPackager v2.0.2
2. Once you have installed the SmartPackage program, it is a good idea to Reboot your system so all files get updated properly.
3. Start the icon called Smart Packager.
4. Under Smart Package, make sure you are under the Welcome screen and click on the Discover a new Package under Common Tasks.
5. When the Blue Discovery screen pops up, click on the Next button
6. Under the New Package Information screen, type out Creatacard Gold3 or something that you like
7. Under the Output Folder, Click the Browse button and select a folder or location where you want the new Creatacard Gold3.msi to be saved. Make sure you click on the Show advanced Options box below and Then Click Next
8. On this screen, you will now need to Click on the Start Discovery. This is what the SmartInstaller program will use to see where all the files are being installed to, etc when you run the Creatacard Gold 3 installer.
9. Insert the Micrografx Creatacard Gold 3 CD in the drive and install the program like you normally would. Please remember to install any of the Extra Free fonts as well during this time since this will be the only time you will have to create a new 32-bit installer (unless you run this process again)
10. After the Creatacard Gold 3 program has installed, verify it is working by Running the program and testing out various things within the program. (This is while the Discovery is still running in the background)
11. Once you have verified the Creatacard Gold 3 program is running properly (under the Windows XP system) then go back to the Discovery window and click on the Red Stop Discovery button and then click on the Next Button.
12. Make sure the Add new package to Smart Packager is checked and then click on the Finish button. This will now save the new "updated installer" MSI file over to the folder location you specified under option 7 above.
13. Copy this new *.MSI file you just created and either burn it to a CD-RW or copy to a Flash drive and take this file over to your Windows 7 system.
Please note, these instructions are an overview and may not contain the entire correct order. The last time I performed this was back in January 2014 when I first discovered the article about using Scalable Smart Packager to re-create an installer file into a true 32-bit installer.
For me so far, the installer has worked with Photoshop 7 and several Photshop plugins like KPT5, KPT7, etc.
I make no guarantees that this will work in your situation but it could not Hurt.
Plus, should you have problems removing this program I would recommend you try this Free program called Revo Uninstaller v1.95. This is Free for Home/Personal use only.
Hopefully you can use the above instructions I provided and get this great program to work under Windows 7.
Please let us know if this process worked for you or not.
Nov 23, 2013 | Broderbund American Greetings Creatacard...
Uninstalled the HP6300C series software since it no longer worked wirelessly. However, we cannot re-install the software. We have Windows 7 OS, the software indicates Xp and Vista. Could this be the...
Access the manufacturer's web-site: http://support.hp.com
Enter the model-number of the printer, and do the search.
Select Downloadable Device-Drivers.
Select Windows 7.
Download the device-driver.
Install it.
Jul 13, 2011 | Office Equipment & Supplies
I am trying to download iTunes onto my computer, but when I get to the end of the process where iTunes and QuickTime are to be installed it wont. A small box pops up saying "iTunes could not be...
Hi there!
There can be several reasons why you are getting this error message. First, make sure that your user account is an administrator account. If you are sure that your account is an admin, follow this steps:
1. Choose Run from the Start menu. type %Temp% and click OK. delete all files inside the temp directory 3. Click again on run from start menu. Type cmd and hit Enter. 3. Drag iTunesSetup.exe from the Desktop into the C:\\WINDOWS\system32\cmd.exe window. 4. Add a space and then this text: /extract %TEMP% 5. Press return/enter. This will extract three Windows installer packages into your TEMP directory. 6. Navigate back to your TEMP directory. 7. Launch the AppleSoftwareUpdate Windows Installer Package. Complete the installation. 8. Launch the QuickTime Windows Installer Package. Complete the installation. 9. Launch the iTunes Windows Installer Package. Complete the installation.
Please reply if this will not fix the problem. Cheers!
Apr 23, 2011 | Apple iTunes
Problem Installing itunes 9.2!!
re install the i tunes 9.2 during installations use the CUSTOMS settings on installing on it. then try to download again
Jul 14, 2010 | Apple iTunes
Hi Name is Joe.
Resolution
Installing on a Windows Vista computer
Creator 2010 requires a minimum of Windows Vista Service Pack 1 for installation. You can either perform a Windows Update (recommended) or install Service Pack 1 for Vista here.
Installing on a Windows 7 computer
The issue might be caused by the Creator 2010 setup package running in Windows Vista compatibility mode on Windows 7. Please use the following steps to turn off Vista compatibility mode for the Creator 2010 setup package:
  1. Right-click on the setup package and choose Properties.
  2. Click on the Compatibility tab in the Properties window.
  3. In the Compatibility mode section, uncheck the box that is labeled Run the program in compatibility mode for Windows Vista.
  4. Click OK to save the changes.
  5. Re-run Creator 2010 the setup package.
May 04, 2010 | Roxio Creator 2010 Full Version for PC...
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
HP Digital Media Archive Pop UP
If you are running windows xp, go to start / run . type: msconfig
Go to the start-up tab and see if you can find a reference to the "Digital Media" program and uncheck it.
Also look in the start-up folder in Start / All Programs for this program.
You can delete it from there. This does not remove the program, just does not tell it to start automatically. If you don't use the program, uninstall it.
Sounds like one of those ADD-ON programs that get installed with printers or cameras.
Jan 04, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
