Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer was making a funny noise when it spun out. Today the water started leaking out of the detergent dispenser bad. How can I fix this??
  • Whirlpool Master
  • 2,694 Answers
Check around the rubber boot up near the top or to the left of the middle top,see if a sock or something is blocking the water line up in there.something is stuck up there blocking the line,if you look at it like a clock look at like eleven oclock and see is anything is stuck there
Posted on Nov 09, 2010
  • 1 more comment
  • Sal De Nov 10, 2010
    there's a plastic piece sticking through the boot,stick your finger up in it and see if you feel anything in it,this is where the dispenser drains into the machine,if it's leaking out from the front it has to be blocked with something,let me know what you find
  • Sal De Nov 15, 2010
    also if it's making a loud banging noise like the washer is off balance you could of broke the spider gear or a shock but most likely it will be the spider gear,if that's what you're discribing then it's to much money to repair,let me know how you made out
  • randy203 Dec 17, 2010
    Our soap dispenser water line was clogged with soap build up and once we cleaned it, the leaking stopped.
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
My Whirlpool Duet washer is leaking from the
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking badly. when it starts filling water rushes out of the detergent dispenser and the bottom of the door.
Jul 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer, dispenser problem with fabric softner
maybe it's clogged take the drawer out and see if the water flows out of that side ok. put into rinsea nd spin and it should put water into that side.
might take a minute
What happens let me know
make sure you have a towel ready
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Oct 17, 2009 | Whirlpool WFW8300SW
Whirlpool front load leaking water from the detergent dispenser
Could be pressure too high reduce feed to machine only ....Slightly...Also try cleaning just in case its blocked
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 110.4751
for the F10 code ? Unplug the washer open chech the funny noise / belt are worn out / slap to the brackets and other near obstacles . Replace belt broken.
Detergent leaking /ovewr flow clean w/ fish nylon # 150 just 40 cm /insert in the hole put water to soften the hard detergent forward and backward to clean detergent hose.
Nov 15, 2007 | Kenmore 43142 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal De
