SOURCE: transferring of contacts
just go to contacts and look for the copy to sim or copy to phone. just try.
SOURCE: transfer contacts list
1. From the standby screen (the first screen when you open your phone), go to the menu.
2. Scroll to the address book and press select.
3. Scroll to the address you wish to copy (or any address if you want to copy all of them) and press the menu key.
4. Go down to copy and press select.
5. Select "Entries" to copy just that one entry or "All to SIM" if you
want to copy all your addresses to your SIM card, or "All to Phone" if
you want to copy them all to your phone.
6. Select Merge or
Override. Merge will combine any addresses that are already on your
card with the ones you are now copying, Override will replace anything
that is already there with the ones you are now copying. Be careful in
deciding which you want to do since Override will delete anything
previously saved and merge will duplicate any that were already saved
and are being saved again.
SOURCE: Copying contacts from Phone to Sim Card
1 take you to the main menu.
8 gets you to your contacts.
Very top left button with three dots gets you to options.
Then you have to hit the down button 12 times, to get to 'Copy to sim'.
Then hit 2, to select multiple.
Then hit the middle button to select all.
Then hit the very top left button again to copy.
And it will ask you to continue, and hit the very top left button one more time.
Then wait until it has copied them all.
But since you have no screen, you probably won't know when that is, unless it makes the noise it makes when it is done with something. Or just wait a few minutes until you think it is done copying.
Hope this helped.
SOURCE: transfer contacts from a sim card onto cell phone
Go to contact list and select the contact.press option button then press copy option then press copy to phone.
SOURCE: Samsung SGH-M310L, The screen is broken how to transfer the info?
This would be hard as you cannot see anything on the unit but you should be able to hook it up via usb and grab the files you want off it but contacts should be on the sim. www.pdarepair.com can fix that screen for you so you do not have to go through all this. thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
