Question about Maytag Refrigerators
Water on floor from freezer side,ice build up on floor of freezer side
  • Maytag Master
  • 2,180 Answers
Is it a side by side?if so you have a plugged drain,if you can remove the bottom draw or bin,if you can't shut down the machine and with a hair dryer melt out the ice,when you remove the bin look at the back wall at the bottom,there's a hole there,when the heater comes on the ice melts off the evap coil and the water should drain down the hole but it's not,you have to melt out the ice and clear the drain out,i use a steamer but you can use like a baster or try to snake something through the hole like a piece of the hose that they use for the water lines on the machine or a plastic wire tie,when you think the drain is clear pour hot water into the hole,if the water drains then it's unplugged,if like a half a cup of water doesn't drain down it's still plugged but you have to clear the drain,the line is made of plastic so don't go crazy sticking stuff in there that will cack the drain line or you'll really be in trouble.let me know how you make out
Posted on Nov 09, 2010
WHY IS MY SIDE BY SIDE WHIRLPOOL leaking water onto floor?
normally caused by a clogged drain in back of freezer . check to see if you have ice build up on bottom of freezer..... gently chip away ice in freezer and turkey baste hot water into drain hole until water flows freely
Aug 27, 2014 | Whirlpool Refrigerators
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
Ice builds up on floor of freezer apparently some leaking as my lamented floor is showing some damage. i have cut off water supply to icemaker and water tap thinking this was problem.
most likely you have a plugged and frozen defrost drain. check behind the bottom basket of your freezer section to confirm this you will find alot of ice build up. to repair you self:
  • unplug refrig.
  • unload freezer section
  • remove rear access cover (on jenn-air's there are 2 screws about mid way up they are painted white and arent very obvious).
  • clear all ice
  • flush drain hole with warm water. ( i use a turkey baster filled with hot water to get best results)
  • reassemble unit
  • reapply power
this should stop your water leak. thanks Peyton
Oct 10, 2010 | Jenn-Air JSD2789GES Side by Side...
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Magice Chef side by side builds up ice on freezer floor
it sounds like a defrost element on the evap. if ice builts up and the elemet is not working then it will build ice on the evap and not cool.....
Jul 27, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
My refrige leaks water on the floor from the freezer side on the left. I turned the water off and disconnected the water line. Still once or twice a week the refrige leaks water on the floor.
Sounds like ice build up on the freezer coils. Disconecting the water line doesn't stop regrigerant from flowing through the coils since they are still working. Easiest way would be a hair dryer to melt the built up frozen consensation. After you should see no water on the floor and you can turn the water back on (i assume the water is for your ice water and ice cube tray).
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice build up on the bottom floor of the freezer
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Nov 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
