Question about Canon Office Equipment & Supplies
`bjc 80 driver will not load on vista printer driver not installed -- error -- 0x0 -- 02
  • 4,472 Answers
There are no Vista drivers available for this printer. It will not work on vista. You will have to upgrade to a new printer.
Thanks,
Lee
Posted on Jun 17, 2008
Trying to hookup bjc 80 to acer aspire 4730z running vista, don't have disc but am hooked up via usb.
you need the printer driver for vista in order to be able to print out. But Canon does not offer drivers for XP and Vista for bjc-80, however you can manually install the driver for BJC-85 and get the printing function going, but the scanner cartrige does not work through USB.
BR
Bruce
Oct 23, 2009 | Canon BJC 80 InkJet Printer
BJC 80 w/ Vista OS prints 1/2 page and goes to error mode.
Purchase a PCMCIA parallel port card. That's a PC Card parallel port adapter. It provides a native parallel port to laptops that do not have one built in. Works perfectly in ALL cases, even with the scanner cartridge.
Jun 09, 2009 | Canon BJC 80 InkJet Printer
Compatibility with Vista, or are drivers available.
by looking at the table in this link, supposely this printer works fine as plug n play to your vista...no driver installation is needed....
hope this will help ; )
http://support-my.canon-asia.com/index.jsp?fuseaction=support&prod_type=vista_list
May 26, 2009 | Canon BJC 80 InkJet Printer
BJC -85 Setup Software wil not download to Vista...not compatable.....What can be done to se the Printer/Scanner on my computer with Vista.
As the link (http://www.usa.canon.com/consumer/controller?act=OSCompatibilitySupportAct&keycode=vistadr&fcategoryid=230&modelid=6620) in Mike's solution states, "Driver included with OS. Download not required.", i.e. Vista comes with a driver for the BJC-85 so you don't need to download one. I've just connected my BJC-85 to my new Vista machine and the printer was detected and drivers loaded automatically.
Feb 18, 2009 | Canon BJC 80 InkJet Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Canon bjc 85
Vista driver for this machine comes stnadard with vista but will not work when old xp drivers are present (or were when upgraded to vista) , remove old driver from system, connect printer,  vista should auto reconise and install.
Here is a canon link explaining Vista with BJC 85
http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=230&modelid=6620
Oct 31, 2007 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
27 people viewed this question
old marine
old marine
