Question about Bissell 8910 ProHeat Clear View Upright Vacuum
I havea Bissell ProHeat Model 7901. My problem is that the brush doesn't rotate. I have removed the access cover and both belts and found that the central cylinder for both belts is frozen and will not turn easily. Both belts are fine, except they are now burnt from this cylinder not being able to rotate. What I need is how do I remove the top cover to get at this cylinder to remove it and free it up?
    Top Expert:
  • Bissell Master
  • 7,915 Answers
Clean bearings on rotator possibly ruined motor
Posted on Feb 08, 2018
  • 48 Answers
SOURCE: connecting a BISSELL AUTO MIX PISTON TO A AUTO MIX KNOB
Take of the housing ,turn it over and you will see the under side of the auto mix dial , Then turn the auto mix dial to rinse only;
On the top of the piston you will see a small slot , this fits into
the out side spiral on the auto mix knob with the dial set to rinse only the top part of the spiail sould point to the courner
Tilt the piston slightly,then hook it on the point of the auto mix knob , when you turn the auto mix dial to heavy traffic the piston should slide down the outer spiral of the auto mix-dial ,
Put the housing back on with the auto mix dial set to heavy traffic, but make sure no tubes are trapped or this will stop the flow of water,
i hope you can under stand what i have wrote ,Goodluck
Posted on Nov 29, 2007
  • 8 Answers
SOURCE: Water will not come out to do floor work
UPDATE! I changed the pump on my Bissell Pro-Heat 7901-1. This corrected the problem.
Pipert
Posted on Dec 18, 2007
  • 10 Answers
SOURCE: Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!!
Posted on Sep 26, 2009
VacuumRepair
  • 438 Answers
SOURCE: Bissell Proheat model 7901-1 is there diagram of
I have pasted a link to the Bissell ProHeat series carpet extractor repair guide below. This guide is like my Bible when I'm working on these machines, and is EXTREMELY helpful on explaining how, and where hoses and parts go, and possible explanations of problems, and how to fix them.
I hope that this information is helpful to you, it sure is to me. If you did find this helpful, please be so kind and vote my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair. This is what really keeps repair professionals like myself keep coming back and giving free repair advice, we greatly appreciate when people acknowledge our work here. Thank you ahead of time.
Bissell ProHeat Repair Manual
Thank you again,
Chris J.
GoVacuum.com
Posted on Apr 15, 2010
heatman101
  • 43501 Answers
SOURCE: Info on how to operate a Bissell Turbo Brush Model 7901-P.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
345erw
Posted on Sep 30, 2010
I have a bissell 7901-1 carpet cleaner and the gear the runs the beater bar is loose how does it connect to the pump thanks
turn your unit over so you are looking at the bottom (side towards floor) on either side of the brush are a phillip's screw- one side will show a larger red piece- take that phillips screw out, it will show you the pump you can take the belt access cover off and see the one belt, the belt to the beater brush is gear like- take the belt that connects to the brush and loop it over the gear on the pump- then put the brush belt over the brush and seat it back into the protector- I would suggest you hand spin the brush to ensure both belts and the pump are turning otherwise You may do like I did and burn the other belt- I replaced both belts just because it made sense- reseat the red piece you removed then replace and tighten the screw-
Nov 22, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How do I replace the elevator lever arm on my bissell 7901-6 steam cleaner
i have a bissell 7901 and i recently replaced the brush belt. now my problem is the brush while is working the brush is not making contact with the carpet. how can i adjust the brush?
Nov 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Replace belt on Bissell 7901 Proheat
On the underside of the unit, you will see a red cover about 1 inch square held on by a phillips screw on one end of the brush roller unit...remove it & you will see the toothed rubber agitator brush belt.
Sep 05, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a Bissell Pro Heat Carpet cleaner and the brushes will not turn. The pully is not turning the belt.
if the motor shaft that rotates the belt to turn the brush does`nt turn you have motor problem`s if it does you need to free up what ever is keeping the brush froom turning freely
Nov 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Need to replace red clips that hold rolling brush on 7901 Proheat
On the bottom of the machine, near the belt access area,
is a red retainer plate that holds the black brush arm and
brush in place. Using a Phillips head screwdriver remove the
screw that holds the red retainer plate in place. p/n 5559113
Jul 12, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
heatman101
345erw
Apr 09, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
The brush will not turn
Hi! Your question has come up under Bissell ProHeat, so I'll assume that's the model you're talking about.  There are several possibilities. The simplest is that the drive belt has broken. There are two drive belts on the ProHeat and you're best advised to go to the Bissell website (www,bissell.com) where you can download a manual for your exact model.  Worst case scenario, which I have seen, is where the brush drive motor has become wet, it has corroded and will no longer rotate, and this burns out a little circuit board that's located in the handle. If your belts are OK, and the brushes are free to rotate, there's probably a problem with the motor and I strongly recommend consulting a professional repairer. Getting in to the machine is a minor nightmare, and getting it back together is worse. The cost of such a repair may well exceed the value of the machine. Good luck!  I value your feedback.  If this has helped please remember to rate me.  If it hasn't helped, please re-post with more details and I'll try again.
Feb 17, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Brushes wont rotate
heatman101
uyk
Dec 24, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Found my problem...
to replace the pump belt , make the machine safe ,
Remove the pump belt cover Turn the machine over ,You must remove the floor brush,
You will see two red retainers on either side of the machine ,remove the screws which hold these on ,remove them .
pull the pivot arm out of there slots remove the brush,you will see the brush belt remove all these ,
you can then feed the pump belt over the end of the pump and motor spindle .refitt in reverse order
All this should be in the instructions, Could luck
Oct 20, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dirtlifter Powerbrush does not turn
Make the machine safe from the power source first
When you remove the belt access door you are looking at the pump belt,
To gain access to the brush belt you must turn the machine over and remove the brush at the bottom of the machine.
there are two screw in the red retainers at each side of the brush, remove the screws and the retainers and the pivot arms ,you should see the brush belt and the pump
Jun 07, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
