Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile side by side refrigerator and the dispenser no longer works. The lights go bright and dim, but nothing happens.
  • GE Master
  • 2,516 Answers
There's a computer board on the back wall,most likely it needs to be changed,G.E. has been having alot of problems with their boards and everything runs through it,i believe the part number is wr55x10942 but call your parts store,give them the model number on the machine and they'll give you the correct part,it's around 150 to 200 bucks,i've changed a few with the same problem,on some of them the fans run slow then fast,if the water dispenses the compressor shuts off or it won't dispense at all just like yours.let me know how you make out
Posted on Nov 09, 2010
GE PSS26SGRCSS cube and crushed ice door dispenser is intermittent. When green dispenser light and dispensing light is bright, it works normally but sometimes when a glass is pressed against the lever both...
Had the EXACT same problem with another GE side-by-side. Repairman just left and it was the main board that had to be replaced. It took him all of 5 minutes to replace and cost us $318. If you are handy, it is a repair you may be able to do on your own if you can find the correct model number and order it.
Dec 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
When pushing ice dispenser on GE side by side light dims and nothing happens
sounds like a large current draw is causing the light to dim most likely the cause is a build up of ice around the auger motor or the auger is seized.
Mar 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water and Ice dispenser quit functioning
the solution to this problem is so simple it makes me laaugh out loud. the bulb in the door that illuminates when a glass is placed under the water dispenser draws too much current when it gets old. just remove the bulb and it will work fine. you can then replace the bulb whenever you find it at a hardware store. I had the same problem, and spent hours online looking and was ready to buy a new motherboard to fix it. I have alot of faith in GE, and all of the bashing is a horse ****. GE makes turbine engines that power alot of the airplanes we fly in and i think they know a thing or two about engineering.
Jun 10, 2009 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser not working
your welcome sorry i wasnt able to save you a service call
Mar 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
238 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
