Question about Briggs & Stratton Garden
I have a Flymo RL188M with a Quantum 50 Briggs & Stratton motor and I need a user manual so that I can learn how to change the air filter and spark plug
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
they were in/out.
Please do not forget to rate me, Thanks
Posted on May 26, 2010
mikehowy
  • 177 Answers
SOURCE: I would like a user manual for a Champion R484TR lawn mower.
google
Posted on Jun 07, 2010
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Posted on Mar 29, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
Have a Quantum xte with a 5.5 b&s motor what spark plug does it take
Larry, All plugs listed below should work in your 5.5 B&S Quantum engine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
  • Genuine Briggs & Stratton Part 802592
  • Replaces Champion J19LM or RJ19LM
  • Also is the same as NGK B2LM or BR2LM
  • Also is the same as Autolite 458, 308.
  • Briggs & Stratton new number for 802592 is now 796112
May 06, 2016 | Cars & Trucks
Need to know where the fuel filter is located
FAQ: Fuel Filter Replacement ' Briggs & Stratton Engines
www.briggsandstratton.com/us/.../fuel-filter-replaceme...
Briggs & StrattonWith this Briggs & Stratton FAQ, you'll learn how a fuel filter works in small engines ...properly strain the gas before it reaches the carburetor in your lawn mower, snow ...and uneven operation; Clean filters conserve the amount of gas you need ... The fuel filter will be located either inside the fuel tank or fitted into the fuel line ...
Servicing the fuel filter - Briggs & Stratton
www.briggsandstratton.com > www > Support > FAQs
Briggs & StrattonIf you still need help, you can submit your question by clicking the Ask a Question tab.... Some filters are located inside the tank, others are fitted into the fuel line between the tank ... The size of the holes in the filter will determine the largest particles that can get through the filter, and the number of ... Lawn Mower Engines ...
Lawn Mower Engine Fuel Filter Installation - Briggs ...
Jan 01, 2016 | Garden
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
Overheating briggs & stratton motor model #126t02-0487-b1
what do you mean by overheating make sure all the fins in engine are clean and free of debris and also the top of flywheel is clear as well it must be to keep it running cool
Jun 04, 2013 | Garden
Hi, i just swapped my elec flymo for a briggs and stratton 35 lawn mower, however when ever i start it it coughs and splutters and wont run for more then 30 secs and is also spitting out oil from exhaust....
if the motor has been on its side the oil has runs out thru the muffler and air filter. briggs are famous for doing that. let it sit overnight and remove the air cleaner and you see is fill of oil. next day take the spark plug and clean it and check the gap then put it back, take carburator cleaner and spray some inside the carburator, check the oil level and start.if it wont start then is time to clean carburator. the air filter if is wet in oil and is the dry type. get a new one.
Feb 08, 2011 | Briggs & Stratton Garden
My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
Jun 19, 2010 | Briggs & Stratton Garden
What's the recommended oil for this engine. can't find my manual
You can use 10w30 weight year round. I highly recommend you use synthetic oil in this air cooled engine and change the oil/filter every 50 hours. I think you will find it holds 1.5 quarts with filter change. Do not overfill.
Apr 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
249 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
