Question about Microwave Ovens
My GE oven model jbp82s0h2ss flashes on the display locked door, although it is not locked. and i can not use the oven now HELP!!!!!!!!!!
Oven wont work unlock door meesage keeps flashing door unlocked
The model number would have helped us give you specific advice, but without it we'll give you generic advice and say it may be a door switch issue.
See our help file on door switches here.
Jan 16, 2013 | GE Microwave Ovens
Microwave is locked up. Says Lock on screen and cannot get it to go away after hitting Clear several times. How do I get it off "lock" status?
HELLO.
GE manufactures various models of microwaves with a range of features.
Among them is a child safety feature that allows parents to lock the keypad. Though children can still open the door, the keypad lock prevents them from starting the microwave. The lock is in the form of a keypad code that renders the buttons inactive.
* 1 Press and hold the "Clear/Off" button on the microwave's keypad.
* 2 Hold the button down for three seconds.
* 3 Wait for the "L" on the keypad's display to disappear and display the time instead, signifying that the device is no longer locked.
Willing to help solve more problem.
Thanks.
Aug 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave display flashing & beeping.
You have a failed membrane keypad.
On this model, GE doesn't make any parts available except the tray and the roller.
If it's in warranty, they will exchange or repair it.
It it's out of warranty, you're out of luck.
I'd advise you to contact GE Customer Service in case they may be able to help you.
Jul 25, 2010 | GE JES1036PWF 1100 Watts Microwave Oven
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
I have a GE microwave with the message sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE zmc1095 microwave beeps and indicates "HOT" in the display
If it stops heating it needs a new magnetron. our oven is less than 2 years old and has gone thru 2 magnetrons so far. Hoping to get some help from GE.
Jan 28, 2009 | GE JVM2050 Microwave Oven
My microwave oven is displaying sensor error
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Nov 19, 2008 | GE JE620 Microwave Oven
GE microwave model jes1456 has sensor error
Aug 23, 2008 | GE Microwave Ovens
Control locked
If yours is a GE JVM1640 or similar GE model, here's what the owner's manual says:
To lock or unlock the
controls, press and hold
CLEAR/OFF for about
three seconds. When the
control panel is locked,
an “L” will be displayed
to the extreme right.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
83 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
