Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE refrigerator 197D3351P006. The door controls aren't working any more but the light will come on for each selected control (water, crushed, cubed). I pulled the panel off on the inside of the freezer near the light bulb and found a green wire hanging out with a metal clamp on the end of it. It appears that it's supposed to clamp onto something but I can't figure out where or what it clamps onto.
Krazytech
  • 725 Answers
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Posted on Apr 05, 2008
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: crushed ice only
Thank you for contacting Electrolux Major Appliance. Please remove the
ice bucket. Against the back freezer wall, you will see a square
opening with either a white or clear switch that can be adjusted up to
down. If you have a blow dryer, blow dry the square opening for 7 min's.
Once done, adjust the switch. It will either move freely or will
remain in its opposite position. Replace the ice bucket. This should allow
cubed ice.
Posted on Aug 16, 2008
MNTECH
  • 1543 Answers
SOURCE: Ge pss26sgrc ss ice/water dispenser
Take the outer frame off the dispenser area with a plastic putty knife. Start at the bottom and gently pry off, trying not to snap off plastic tabs that extend into door. Most likely you will have to replace the "interface" (part # WR55X10415) It is the small board where you select water / crushed ice / cubed ice. Relatively easy to replace. good luck.
If this helps, please rate response. Thanks.
Posted on Aug 27, 2008
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
GE Profile refrigerator panel on front has stopped responding to requests for ice. It give water, but no ice. Any ideas on what is needed?
Yes, we will need to check the wiring from the motherboard to the dispenser controls. Also we need to test the door switch. The door light switch works two ways by turning on light when open and turning on dispenser controls when closed. Sometimes the door switch is bad. I have a link and will work with you to solve this, Let me know, Thanks, Sea Breeze
Apr 18, 2010 | GE Profile PSS26NGS Side by Side...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Jul 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Lights are on controls on not cooling
hi thanks for the question Your fridge is stuck in defrost cycle replace defrost timer. THanks for the Question The appliance doc
Sep 12, 2008 | GE PFS22SBSSS Stainless Steel French Door...
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Mar 10, 2007 | GE GSH25JFR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
93 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
