Question about RCA D52W19 52" Rear Projection Television
Electrical zapping noise , tv turns off after starting
I have been hearing a zapping noise coming from my tv when i turned it on.
After awhile the tv would zap again and shut off and then turn back on a few moments later. Now the tv will not start up but i will still get the zapping if i try to turn it on. i took off the back panel and plugged it in, turned it on and their was a small fire and smoke and then the tv turned off. This was the zapping noise . i took the piece out that was causing the fire but i have no idea what it is. it is a small rectancle with numbers r73,.0087,h 2000vdc,kp,s9,qa20311. All numbers and letters are separated and in different places on the piece. the board has a burn mark on it from where it was removed. any help would be appreciated.
  • 9 more comments
  • Anonymous Jul 14, 2008
    i got the same problem.. please let me know if you found this part..
    thank you
  • birdii Jul 14, 2008
    i have the same problem with this part... did you find out where to get this part?
    thanks!
    thank you
  • mjschmitt_ar Aug 17, 2008
    same problem same part....has anyone fixed theirs yet. mine has been down for quite some time but i have been hesitant to replace it just because i'm not sure that it is the only problem.
  • toolz1 Aug 21, 2008
    Mine was doing exactly the same thing, with the noise and turning off and restarting, but would eventuallly come on and work normally, sometimes would even start normally. Then one morning I turned it on and the picture would not come in, at the bottom of the screen was three semi-spheres, blue red and yellow, in the middle of the screen was a thick black line, and moving across the screen diagonally were several thin, wavy black lines, and the remainder of the screen was filled with tiny colored dots. This is when I unplugged it and returned to teeny vision (smaller tv from bedroom). Today I found this thread, sounded very familiar, took the back off the tv, found the suspect part, but I have no burn marks around it, or anywhere on any of the boards, so now I am completely lost again, and cannot afford a repairman, any help greatly appreciated - Thanks
  • Anonymous Apr 07, 2009
    does anyone know where you can buy a new one of these capacitors?
  • kysauter Apr 09, 2009
    I'm having the exact same problem (only a ticking noise as i try to turn on the tv). For a while the tv would just shut off and now it wont come on anymore. Do you know how much it would cost to have my tv checked out and to have the parts replaced (circuit board and whatnot). I just might be better off buying a new tv....
  • skrappie_dew May 14, 2009
    got a d52w26 for free from craigslist as a project and found the board to be burned through in the same spot as everyone else. Either this is a weak spot electronically or as I'm guessing a bad design in the Circuit altogether. I replaced the whole deflection board and now I am blowing fuses. I figured out that the thing that causes the fuses to blow is when I hook up the large two prong yellow and green wires to the convergence p.s. that are parallel to the +300vdc output to the deflection board. I'm guessing that something is shorted in line with the CRT's but haven't dissected it enough to know for sure. The yellow and green are dead short to each other and the Red and blue are that hook into the deflection board near the Flyback.
  • basementjax4 May 11, 2010
    Correction to my previous post. I said cp130 and meand CL031.
    thanks!
    I have the same problem and finally figured it out today. I pulled the boards out and found the burnt hole on the bottom of the cp130. I have attached a pic of the burned area. Is that replaceable with how badly burnt the board is?
    Thanks!
    -Gabe
  • birdii May 11, 2010
    http://ca.geocities.com/p_b@rogers.com/big.jpg
    heres a pic of the part... thanks
  • RCA Master
  • 8,617 Answers
Can you post a picture of it? It sounds like youre talking about a box capacitor.
Posted on Jun 17, 2008
I JUST SPOKE TO RCA, THE WARRANTY FOR THE WHOLE TV IS ONLY 2 YEARS, GO FIGURE, SOUNDS LIKE A FIRE WAITING TO HAPPEN.
Posted on Aug 22, 2008
I have the same problem today it flashes and lights on fire. what is the part #
Posted on Aug 21, 2008
I work in a TV repair shop and this is the second time I've seen this problem. The first time the customer did not approve the repair so I wasn't given the chance to properly troubleshoot it but it appears that CL031 burns a hole in the bottom of the circuit board usually do to a spike in voltage created by the FLYBACK TRANSFORMER (hv transformer) also check CP150 because it is probably also bad. Usually when the flyback goes bad it'll blow the Horizontal Output transisiter but in this case it does not. I pulled the board and havn't had a chance to put it back in yet but I'm going to replace CL031, CP150 and the FLYBACK TRANSFORMER and I'm reasonably confident this will fix the problem. If not the best course of action would be to order the whole board i.e. the DEFLECTION BOARD
Posted on Aug 19, 2008
I can hear a zapping noise.the front green display is not lit.
Most of the time a zapping or crackling sound is a bad electrical connection. I would check the connections were the power from the source is connected to the oven.
Aug 18, 2015 | Smeg Ovens
Went to turn on tv from the side button and loud zap noise and bad smell coming out!
you horizontal output transformer inside the unit has a high voltage leak.
if you know how to open the back cover. you can try to clean the dust buildup
inside and in the back of the tube check the unit if still produce bad smell.
if still zapping replace your high voltage transformer it may have a leak.
Aug 26, 2011 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
There is a humming noise coming from the trunk. If you hold the lines to the fuel pump, it isn't so bad. Don't think it is a wheel bearing. It starts when you turn on the car, then quits for awhile and...
THE NOISE YOU ARE HEARING IS THE ELECTRIC HIGH PRESSURE FUEL PUMP IN THE GAS TANK, THE NOISE IS CAUSED BY THE PUMPS ROTOR BEARINGS BEING EXCESSILY WORN, IT COULD STOP WORKING TODAY OR KEEP GOING FOR YEARS, BUT THE NOISE IS A WARNING THAT THE PUMP HAS A PROBLEM. I RECOMEND IF IT IS REALLY THAT NOISEY YOU HAVE IT REPLACED.
Mar 29, 2011 | 2001 Audi A4
Makes a zapping noise when you turn on the electronic air cleaner
If the the "zapping" noise you hear is intermitant (like a Bug Zapper) it's probably dust that the air cleaner is picking up from the household air. .If that's the case, there's nothing to worry about, it's doing it's job.
If the "zapping" sound is continuous, then the unit may need cleaning, as it may be clogged with dust & lint.
Feb 08, 2011 | Air Purifiers
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
Ignition, electrical noise
does it have a fuel pump ?...it could be just priming itself..when the pump is already full you cant really hear the noise that much. Does the noise go away after riding for awhile and then restart it?
Sep 29, 2009 | 2005 Yamaha YZF-R1
"zapped" tv (dee7189)
I would need more details on this problem. Does the tv turn on? If so, what do you see on the screen? If you mean by "zapped" that the tv received a lightning strike and does not turn on, it's possible there are several damaged circuit board components. Depending on the severity of the strike, it's possible that just the fuse is blown. I need more details to advise further.
Rick.
Jan 18, 2009 | Insignia NS- 27" TV27 TV
Zapping sound when turn on
Same buzzing sound here...help!!!!!!!!!!!!!!
Apr 06, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Power on power off
IF YOU TV IT'S THIS MODEL # 60P8241 THE PROBLEM IS THE MODULE LOCATED NEXT TO THE TUNER ( SIZE ABOUT 2 1/2 INCH - 4 1/2 INCH). MODULE # 3139 123 5305.5
Jan 18, 2008 | Proscan PS56670 56" Rear Projection...
Get a weird zapping noise
sounds like theres a short, most likely the flyback transformer
take in for service
Dec 05, 2007 | Zenith D52WLCD 52" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
1,469 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
