Question about Hoffco TILLER PRO HOE WITH HONDA ENGINE
I don't have a owners manual. What oil needs to be used and what's the mixture?
What is the correct fuel & oil mixture for a 2006 Suzuki RM80
Hi, Roslyn for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Gas Oil mixture for rm 80
How To Mix 2 Stroke Oil
Suzuki RM85 Owner Service Manual
OEM parts for Suzuki
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 18, 2016 | Suzuki Motorcycles
How many ounces in a gallon
Guess you are asking this because you need to mix your 2-cycle engine oil with gasoline. One gallon = 128 fluid ounces if you are in the US. In the UK, 1 UK gallon = 160 UK ounces.
I totally plagiarized this information from numbers.com.
Not plagiarized: you want to use the correct mixture for your blower to get it to start easily. Your blower probably uses a mixture of either 50:1 or 40:1. I use a product called ProMix Premium that allows me to squeeze the bottle to measure out the correct amount of oil into a gallon of gas. I use two different gallon sized gas containers, one with a 50:1 mixture and the other with a 40:1 mixture. Between the two mixtures, all of my machines will start and run well according to their oil mixture requirements. Usually the machine will have a label on it to tell you the correct mixture, if not, check the owner's manual or instructions.
Dec 11, 2013 | Garden
96 Thunderbird runs bad. Gas/oil mixture draining from airbox.
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Legend Gas Leaking from Airbox Drain HELP
Oil Drip From Airbox
Triumph Thunderbird Service Manual
https://www.triumphestore.com/
Triumph Thunderbird Owner Manual
Aug 27, 2017 | 1996 Triumph Triumph Thunderbird
2006 Kawasaki KX 125 oil fuel ratio
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Best oil to gas mixture for 00 KX 125
help kx125 fuel ratio
03 08 Kawasaki KX 125 250 Service Manual pdf
OEM Parts for Kawasaki
2005 Kawasaki KX125 Owner Manual
Mar 21, 2012 | 2006 kawasaki KX 125
How much oil do I use per 1gallon of gas for a Husqvarna 223L weed eater?
for a 40/1 mixture use 3 ounces of oil ( 2 stroke) to a gallon of gas for a 50/1 ( which is what I recommend ) its 2.5 ounces to each gallon of gas, if you find that the machine is smoking a little too much,, back up on the oil just a hair,, but I don't think you'll need to
Aug 25, 2011 | Husqvarna 28cc Gas Line Trimmer
I need to know what the gas to oil ratio is for a Husqvarna 372xp chainsaw is
Hi gducci1949...
Use a 50 to 1 mixture...1 pint of oil to 6 gallons of gasoline
Please take time to rate me
Aug 22, 2011 | Husqvarna Garden
Ariens TB220 (WeedTrimmer) - What is the gas/oil mixture and what type of oil is proper? Model# 946004 Serial# 003263
Hi marten chris...
You can use any good brand of 2 cycle oil.
It is oil made especially for two cycle motors and marked on the container as two cycle oil.
Not to be used in 4 cycle engines.
Check your weed trimmers requirement for oil to gas ratio and mix it to the specification required, do not put in extra oil as this could cause hard starting.
Jun 19, 2011 | Garden
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
Hoffco TILLER PRO HOE WITH HONDA ENGINE Logo
66 people viewed this question
Top Hoffco Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Hoffco Garden Expert? Answer questions, earn points and help others
