Question about Pioneer DEH2200UB with iPod Direct Control and USB Input Car CD MP3 Player
How do i set the clock? I have tried many ways that i have been told and none work.
  • 8,197 Answers
Welcome to FixYa!
Here is how to set the clock.
Initial Settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press M.C. and hold until CLOCK SET appears
in the display.
3 Turn M.C. to select the initial setting.
After selecting, perform the following procedures
to set the initial setting.
CLOCK SET (setting the clock)
1 Press M.C. to display the setting mode.
2 Press M.C. to select the segment of the clock display
you wish to set.
Hour-Minute
As you select segments of the clock display, the
selected segment flashes.
3 Turn M.C. to adjust the clock.
If you need the manual you can get it in the link below. page 11
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-2200UB_OwnersManual0922.pdf
Good Luck
Posted on Nov 09, 2010
How do you set the time on RC591-A (RCA Docking Alarm Clock)
None of these answers works! When I tried the first option, the clock DID NOT flash at 12:00 a.m. Since that didn't happen, none of the following steps did either.
The second option didn't work either. Holding the set key never made the display go to a colon, flashing or otherwise. Again, using the forward and back keys didn't work as described.
The third option with a link to another website led to instructions on a power tool and had nothing whatsoever to do with the clock on the docking station.
The fourth option doesn't give any instructions after you hit the time you want to set. The time DOESN'T stay where you set it. It once you release the forward or backward keys, it reverts to the original time that was on the clock to begin with.
None of these answers works at all. I was given the iPod touch and the radio docking station secondhand from my sister and she doesn't have either the instruction manual or the special batteries that go in the battery compartment. The clock on the iPod itself is fine. I finally figured out (on my own) how to turn off the danged alarms and timing mechanisms but cannot set the clock.
Nov 07, 2011 | Audio Players & Recorders
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Jul 13, 2011 | McNeil-PPC Android Apps
Panasonic microwave nn-sn668b.. after cleaning it earlier today i went to use it and it didnt work. the time reads 00:00 as if a loss of power had occured (but didn't). The only button that seems to...
If the clock is not set, nothing will work as the controls require the time to be working. Press Clear/stop twice and press clock, set time and press clock again.
Hope this helps.
Dec 23, 2010 | Microwave Ovens
My sony handycam DCR-HC26 is frozen on "clock set"
Hello i am hamid
I need a drive for Windows 7 Help me please
hamid.far12@yahoo.com
Jul 07, 2010 | Sony DCRHC26 MiniDV Digital Handycam...
How do you set the clock on a 1999 BMW 318i please.... have tried every which-way
If you've tried every which way.....the clock is broken. Included in everywhich-way would be the correct way so that didn't work? Cell phone has a clock on it.
Jun 12, 2010 | 1999 BMW 3 Series
Maytag Stove Error Message 5 A6
ok Alvin. help has arived .. turn off the power for a few min ( at the breaker box) turn back on see if clock will set . if not you may have a damaged membrain . now 5 A6 MAY BE A FAULT CODE.. in the control panel is a tec sheet with the codes . hope this will help .. mm
Dec 04, 2009 | Maytag Performa PAV2200
HOW DO I SET THE CLOCK
I've had two Pioneer CD players and they both were set the same way. Turn it off then press and hold the AUDIO button if it has one. Then keep pressing it until it gets to the clock. I think on mine the hour starts flashing. When your done just turn it back on. == Answer == I had this problem too. In the far right corner is the "A" (Audio) button. Turn the stereo off and hold the "A" button until the clock comes on. The hour will be blinking. Use the up and down "Select" keys to set that. Then use the right "Select" key to switch to the minutes. Use the up and down keys to set the minutes. Push the "A" button when you're done. My stereo is older than yours but this is what someone who has one like yours told me to try and it worked
Jul 15, 2009 | JVC KD-SX650 CD Player
Clarion drx6275gv clock
I have tried all of the above solutions, but none of them worked! Does anyone else have another solution? Cheers.
Jul 06, 2009 | Clarion DRB2475
Emerson clock radio cks 3516 military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
Feb 01, 2009 | Emerson Smartset Clock Radio
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Pioneer DEH2200UB with iPod Direct Control and USB Input Car CD MP3 Player Logo
1,323 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
