Question about Amana ASD 2624 Side by Side Refrigerator
Not making ice
Check have no power going to the icemaker.
    President:
  • 2,712 Answers
Reason Numero Uno: Frozen Fill Tube
These units have the fill tube in the freezer ceiling that can keep freezing up. The cure is to replace the existing fill tube with a new kit from Whirlpool, consisting of a modified fill tube and a fill tube heater. You can buy it here. This, of course, assumes the icemaker and level sensing circuitry are attempting to function normally. You can test the icemaker by manually initiating a harvest cycle. Do this by pulling the front cover off the icemaker and jumpering out test points T and H with an insulated wire. The other most common problem is bad optics circuit boards. Keep reading.
Reason Numero Duo: Bad Optics Circuit Boards
If the red status LED is not lit on your ice level sensor receiver (it’s the only LED in there, Hoss, so don’t go gettin’ all cross-eyed on me ’cause I’m using fancy words), then you may have bad optics circuits. Close the freezer door and wait five minutes, then open it back up. If still no status light, then you need to replace the optics boards, emitter and receiver. You can buy them here.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Posted on Jun 17, 2008
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
    Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
    Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
    Oct 01, 2014 | Whirlpool Refrigerators
    I have GE side x side cannot get ice to make or water thru the door I have changed ice maker and water valve also have made sure I have water to refrigerator and no frozen lines so don't know
    if this box is a 2001 or newer it has a filter in water line. if this is it take filter and bypass that whole filter. also these boxs have main control located back of box and all fuctions go thru this board. If older than 2001 check icemaker were plugs in. You can force ejectors to make the ice maker run. cycle icemaker check for power at water valve. The ice maker valve is the small line
    Sep 19, 2014 | Refrigerators
    Icemaker not making ice
    Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
    Here are some basic tips for ice maker troubleshooting2_bing.gif...
    Ice Maker Problems and Ice Maker Troubleshooting
    http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
    heatman101
    Jul 13, 2010 | Kenmore Refrigerators
    4 year old jenn-air refrigerator not making ice
    first please check you water delivery chanel behiend icemaker, it may freeze up... second you water valve on bottom part on the back is duel( one valve for water dispencer and another one for ice maker) you have to check if it is a power going to that icemaker valve, unplug icemaker inside freezer and plug back now check for power but you have acting fast, ask somebody for help... and third it could be icemaker it self... good luck for additional questions please totalcarefl@yahoo.com
    Sep 09, 2009 | Jenn-Air JCD2295HES Side by Side...
    No water inside ice maker tray
    Pour about 1/2 cup of water into icemaker . If it makes ice and dumps , replace the water valve . If ice stats in the tray , replace the icemaker . Also , check the hose going into the icemaker , to make sure it isn't frozen . If it is , replace the water valve . And , make sure the coils are clean of dust , lint , etc ...An icemaker has to be 5 degrees to dump and dirty coils will raise the temp above 5 degrees .
    Aug 09, 2009 | Refrigerators
    Freezer stopped making ice cubes
    If temps are ok, then be sure you ice ben is in properly. if that checks ok, check for water/ice in ice maker mold....Try turning unit off and then on in 5mins. this resets the ice maker...if that doesnt work, need to check for power at icemaker. good power means bad icemaker. no power means bad board.(usually) Would suggest you to have a cert GE Sercvice company look at it if no power to ice maker.
    Jun 09, 2009 | GE GSH25JFR Side by Side Refrigerator
    Icemaker is not making ice
    check the fill tube on the ice maker to see if its frozen upo. if it is you are going to need a new solinoid valve due to it leaking thru the valve and freezing up.
    Apr 05, 2009 | Whirlpool GD5SHAX Side by Side...
    Icemaker dont work after power outage
    Make sure the ice bail wire is not lifted. If it is, the ice maker will not make ice.
    The water valve may have failed to. It's in the bottom back of the refrigerator, and the water line normally connects near where the valve is.
    Let me know what you find.
    Jan 30, 2009 | Refrigerators
    Ice Maker not bringing in water
    Not sure what u mean my supply valve.. that would be in back.. never seen one freeze... check the water vave in back... thats where icemaker water is supplied from.. check for continity or make test wire and put power to valve and see if water makes it to the icemaker.. only need to power for few seconds
    Sep 02, 2007 | Amana ACD2232HR Side by Side Refrigerator
    Amana ASD 2624 Side by Side Refrigerator Logo
    158 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
